85 Camaro 2.8 V6 Transmission
Old Aug 24, 2010 | 11:55 AM
85blkmaro's Avatar
Car: 85 Camaro Berlinetta
Engine: 2.8 V6
Axle/Gears: stock
Hello All
I just bought this 85 camaro 2.8 a few month ago from this guy that was almost was going 2 junked it becase he couldn't sell it every thing else was good body was staright the paint was ok so i could let this car go to waste the only thing that was wrong was that the owner ran the car with very lil oil and mess up the crank berrings and the crankshaft along with the oil pump so i brought it for $250 brought it home took the engine out and rebuild it with new performnance parts from the crankshaft pinstons stage 2 cam timing chain high pressure oil pump rocker arms push rods lifters and i wanted to know what transmission did this v6 come with i want to buy a performance torque converter and also where could i find one i try looking but have not had any luck thanks
Old Aug 24, 2010 | 02:51 PM
JuggaloRon's Avatar
Car: 86 camaro berlinetta
Engine: 2.8, soon to be 3.4 w/ turbo plans
Transmission: 700r4(rebuilt in jan. '10
Axle/Gears: stock 3.23 open
Re: 85 Camaro 2.8 V6 Transmission
it came with a 700r4. there is a difference between the v6 and v8 transmission and i believe torque converters. talk with Dave on some of the turbo threads. project89 is his name on here. see what he ran on his turbo 660.
Old Aug 24, 2010 | 02:56 PM
85blkmaro's Avatar
Engine: 2.8 V6
Axle/Gears: stock
Oh ok cool thanks for the info and i will check with him on torque converter and how drop a turbo in my camaro
Old Aug 24, 2010 | 03:56 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
You're better off getting a later model performance built 700R4 if you're interested in boost. Between 87-90, the 700R4 went through several upgrades in the clutch packs. And yes, there is a difference between the V6 and V8 transmissions, in that the V6 trans has a smaller bellhousing and torque converter.
Old Aug 24, 2010 | 05:19 PM
85blkmaro's Avatar
Engine: 2.8 V6
Axle/Gears: stock
Ok thanks i will look into late 700r4 how much could i get torque converter for?
Old Jun 2, 2014 | 03:34 PM
Big_haws's Avatar
So could you just get a bigger torque convertor and bell housing and use the same tranny with say a 350 or 305?
Old Jun 3, 2014 | 05:33 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Bellhousing is NOT removable. You would have to replace the entire case and rebuild from the ground up...
Old Jun 5, 2014 | 01:58 PM
camaroyoungster's Avatar
Car: 1985 Camaro Sport Coupe
Engine: Chevy 3.1
The V8s also have more clutches inside and 31 spline input shaft iirc compared to 28 spline with v6.
Zane Story
Oct 8, 2015 12:40 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
bryaniskoo
Oct 1, 2015 03:18 PM
Dragonsys
Sep 25, 2015 03:51 PM
