85 2.8 stalls when accelerator is pressed
Old Sep 5, 2010 | 01:55 PM
belialsson's Avatar
the car will do a short stall where all the power is cut for about 1/2 a sec then start up again and continue this three or four times in a row... and it only occurs when i push the accelerator pedal about half way down. I have been told it could be the injectors but i really dont know... could anyone post their thoughts on this issue plz. Thanx
Old Sep 5, 2010 | 02:38 PM
58mark's Avatar
Car: 89 rs, 86 Trans Am
Engine: RS-V6... Trans Am-LG4
Transmission: RS-T5... Trans Am 700r4
Re: 85 2.8 stalls when accelerator is pressed
have you changed the fuel filter?
Old Sep 5, 2010 | 03:47 PM
belialsson's Avatar
yeah the whole fuel system was just replaced short of the fuel rail and injectors. it has a new filter pump and sending unit.
Old Sep 5, 2010 | 10:46 PM
southbay08's Avatar
get an ohm meter and check the resistance on the injectors. Should be at least 12ohm or more.
Old Sep 7, 2010 | 09:38 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Will the car drive at all? Or does it just keep stalling out?
Old Sep 7, 2010 | 05:43 PM
belialsson's Avatar
it drives but you can only depress the pedal to about halfway before it will stall out...
Old Sep 8, 2010 | 01:09 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Check the catalytic convertor, it might be clogged up (the catalyst bed breaks up over the years, and can clog the exhaust)
Pac J
May 17, 2020 10:44 AM
86maro_252
Oct 10, 2015 06:52 PM
amcnellis
Sep 16, 2015 04:16 PM
rjcme
Sep 5, 2015 01:23 PM
