engine question
Old Oct 12, 2010 | 08:21 PM
batsibf's Avatar
Car: 1986 Firebird
Engine: 3.4L Swap is done
Axle/Gears: Stock
engine question
hey all
I had an '82 EL Camino, it had a 229. I was wondering how hard and if it would be possible to put that in a firebird that has a 2.8 MPFI.???
the next question could be remade into a MPFI?????
Old Oct 13, 2010 | 11:48 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Re: engine question
Anything's possible, although a quick google search found http://www.elcaminocentral.com/showthread.php?t=627 which says that the 229 only made 110 horsepower; so it'd be a downgrade, but if you were OK with that, sure why not. People make custom fuel injection $ystem$ for anything.
Old Oct 13, 2010 | 12:05 PM
batsibf's Avatar
Car: 1986 Firebird
Axle/Gears: Stock
Re: engine question
i know what it said but I also know I got more out of it with a little work, the last change I made to it was put 350 piston's, cam up grade, and a couple of other things using the same block but the biggest thing if this engine can fit then the newer 4.3l can be put in.
Frozer!!!
Jan 19, 2024 04:55 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
