Whats your good RPM range ?
Car: 88 T firebird
Engine: 2.8
Transmission: t5
Ive just got my bird back on the road in time for my wedding, before it would rev to 4K then stop like it hit a brick wall, its had a timing chain + fuel filter but i havnt had the chance to sort any timing issues as my stuipid AIR pipe is over my dizzy hold down bolt and i cant get to it ( AIR system coming off soon ! ) but it dosnt seem bad
It now accelerates round to 5.5K then hits a wall
i seem to remember a 92 i had reving/ pulling much further round ?
what does yours do ? im possibly thinking valve float on old lifters.....
Car: 1998 Camaro Z28
Engine: 6.0L
Re: Whats your good RPM range ?
They will hit a wall 4500rpms due to intake manifold/exhaust design. Its a huge bottle neck. 5500rpm is your redline and thats because of valve float. The springs cant handle revving that high. If you want to go higher, you need better springs and open up the intake/exhaust to allow for better breathing.
Car: 88 T firebird
Engine: 2.8
Transmission: t5
ok cool so the fact it flies round to 5.5 is good eh ? guessing my custom plenum has something to do with that,i must take some pics of it now
https://www.thirdgen.org/forums/v6/5...take-work.html
somone here actually posted stock and ported flow numbers for the stock intake.i just dont remeber who i do rember it was for a school project though. ill have to see if i can dig them up, but iirc the stock intake isnt a bottle neck
Engine: 6.0L
That was me actually, lol. The big restriction in the intake is when it takes a 135 degree turn from the upper plenum and goes down each runner, it really narrows down. You can see the numbers went up a decent amount just from gasket matching.
https://www.thirdgen.org/forums/v6/3...ed-intake.html
Engine: 6.0L
itll be interesting to see how bad your intake stomps the stock one into the ground, lol.
thew pizza box kills the stocker and moves peak power up about 1000 rpms, this new intake is adjustable u can swap out the runners at will so u can actually tune were peak power occurs.
iintakes if i go into production with them will come with a 3.5 inch a 4.5 and a 6 inch long runner
Car: 92 camaro rs
Engine: 3.4v6 sc
Axle/Gears: 9 bolt 3.73s
so ur saying my 6500 **** ponit is bad and my 7000+ revs are no good o **** still runs fine ?
Car: 88 Firebird.
Engine: 383 HSR
Axle/Gears: 9 Bolt, 3.27:1 Diskbrakes
Car: '85 maro
Engine: In the works...
Transmission: TH700 R4
Axle/Gears: 3.73 posi
I think he's asking if shifing at 6500rpm is just a waste. And yes. You'll probably be faster if you shift earlier. Are you actually making any power up there without valvefloat?!?! What springs are you using?
Car: 92 camaro rs
Engine: 3.4v6 sc
stock as far as i know motor is not that old is a 3.4 and i seam to pull more in the hier rpms dont think i have ever had valvefloat my lower rpms seam to suck any more
Car: '85 maro
I find that hard to believe. My 2.8 could hardly heave itself to 5500rpm when it was stock.
Engine: 6.0L
Yeah im a lil lost on that one too. Spelling, punctuation and grammar help out a lot dude
theshackle
Sep 17, 2020 08:26 AM
