rear end
Old Oct 20, 2010 | 09:47 PM
92camarorv6's Avatar
Car: 92 camaro rs
Engine: 3.4v6 sc
Axle/Gears: 9 bolt 3.73s
rear end
ok i just got 9 bolt rearend its a pois but idk what the ring or grearing is i got a bad felling it 2.77 and my dad keeps telling me its going to make my car slow
i like the rear end maybe the 10 is batter in ways parts ect but its a dice brake rearend i got thes #s of there ring
looks like i lost them ill pop the cover agin but it had 2.77a maybe that can help o and it came from a red 86 trans am 305 carb with a 700r4 trying to give all the info i can i dont want to lose my times but i do do aot of top end pulls (on the street )
Old Oct 21, 2010 | 06:45 PM
Project 3.4 Camaro's Avatar
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
Re: rear end
Uh...as much as I would like to provide some helpful info there isn't really a question in there...what is it you're trying to find/figure out o.O? If you just want to put in better gears summitracing has them, and from what I have heard, I don't think it matters which size you get as long as its for a 3rd gen, but doublecheck that on the drivetrain board first...
Old Oct 21, 2010 | 07:49 PM
Car: 92 camaro rs
Engine: 3.4v6 sc
Re: rear end
well i have a min spool and i dont want it any more cops think im spening tires and i like the 9 bolt up if the geaing is bad in a v8 car what will it do in my v6 im asking cuse idk nd i kinda need some help on makeing my mined up
cods 0575 029001 bw kp 2.77a just want some in put will this be better at speeds of say 55+ and will it ower my rpms and what about my mpg and my hole shots
Old Oct 21, 2010 | 08:11 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
Re: rear end
a 2.77 gear will lower your rpms per any given speed. mpg on the hwy should get better around town may or may not change much...lower rpms but, takes a little more grunt work from the motor to get rolling. that being said, "hole shots" will be non-existent. If you have a mini spool and just want to get rid of it, put a posi in it.
Old Oct 21, 2010 | 08:39 PM
Car: 92 camaro rs
Engine: 3.4v6 sc
Re: rear end
so do i just buy the ring gears and suff
Old Oct 21, 2010 | 08:40 PM
Engine: 3.8, 3.4
Re: rear end
you need a posi carrier to replace the mini spool one....and someone jog my memory on what exactly a mini spool is?
Old Oct 21, 2010 | 09:20 PM
Car: 91 Camaro
Re: rear end
its basically a light weight, solid carrier. no spider gears, clutch packs, nothing...just solid.
you need a posi for the rear in the car or a gear set for the 9 bolt and hope the posi is good in it.
Old Oct 22, 2010 | 06:58 PM
Car: 92 camaro rs
Engine: 3.4v6 sc
Re: rear end
ok well i guess ill just sell it
Old Oct 22, 2010 | 10:28 PM
Engine: 3.8, 3.4
Re: rear end
from what i read up on them i wouldn't use one on anything other than a dedicated drag car...
Old Oct 22, 2010 | 11:10 PM
Car: 92 camaro rs
Engine: 3.4v6 sc
Re: rear end
ye im just going to take the spool out its my dd and im going to sell the 9 olt and but my money in to my supra and some in to my lsx motor for thr camaro
hectre13
Dec 11, 2023 08:14 AM
Warlocksirix
Sep 3, 2015 12:26 PM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
