85 2.8 not starting, help!
Subscribe
Nov 2, 2010 | 06:19 PM
my 85 stalled the other day and i can't get it to start anymore.
it has spark, and the fuel pump works i can hear it turn on, and i checked the pressure and it was at 40. i need to double check since the gauge started leaking (first time i used it, didnt tighten it enough.)
it doesnt smell like its getting fuel and missing though, so i think its still a fuel issue.
is there like a fuse or something that would shut off all the injectors? would the oil pressure switch/sending unit prevent it from starting if it went bad?
im running out of things to check.
Reply 0
Nov 3, 2010 | 08:33 PM
Re: 85 2.8 not starting, help!
Get a mechanics stethiscope or a long screwdriver held against the ear and place it on an injector & turn over the motor. You should hear a distinct ticking noise if they're working.
Reply 0
Subscribe
