MSD OR ACCEL ??
Old Nov 18, 2010 | 12:36 PM
86 Camaro joe's Avatar
Car: Camaro
Engine: 2.8 tune port
MSD OR ACCEL ??
ACCEL 140011 - ACCEL Remote Super Coils
or
MSD Ignition 8226 - MSD Blaster Replacement Coils
witch is recommenced ?
for camaro v6 2.8
Old Nov 18, 2010 | 03:48 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Re: MSD OR ACCEL ??
Really just depends on the brand you prefer. I started out with an Accel 140008, electronic super coil, it came with a harness adapter. It's not a direct replacement, so I had it mounted on the alternator bracket (lots of vibration there!); it lasted for years. Then, even though the Accel was still working, I changed it for an MSD Blaster SS Coil (made a custom bracket to hang off the A/C evaporator box), it's been there for years. (Later I added an MSD 6AL box)
So really it's whichever brand you like, or whatever's on sale- both brands are durable and will be better than your 24-year-old original coil.
Old Nov 18, 2010 | 04:05 PM
texascat2's Avatar
Car: 1989 Forumla 350 WS6
Engine: 5.7 TPI:Bosch III's 22#'s
Transmission: 700-R4
Axle/Gears: BW 9 Bolt Posi- 3:27
Re: MSD OR ACCEL ??
or
for camaro v6 2.8
You have two posts on the same topic! I replaced my dead factory coil with an Accel. Been on there for 8 years, no problems at all!
Old Nov 18, 2010 | 05:18 PM
Project 3.4 Camaro's Avatar
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
Re: MSD OR ACCEL ??
Most people prefer MSD, including myself, I've heard accel is overrated and overpriced...but idk cause I've never used it, my car has MSD cap&rotor, MSD coil and they work great.
Old Nov 18, 2010 | 06:03 PM
FireInMe17's Avatar
Car: 1990 Camaro RS
Engine: 355 Vortec TPI LT4 Hotcam
Transmission: TH700-R4
Re: MSD OR ACCEL ??
I want this one just because it has yellow lettering like my dash, haha.
http://www.summitracing.com/parts/PRO-66937C/?rtype=10
Old Nov 18, 2010 | 06:40 PM
Engine: 3.8, 3.4
Re: MSD OR ACCEL ??
Personally I like red ignition components, my plug wires, cap, rotor, and coil are all red.
Old Nov 19, 2010 | 02:58 AM
FireInMe17's Avatar
Car: 1990 Camaro RS
Re: MSD OR ACCEL ??
I want to paint my valve covers red once I rebuild the engine, but other than that, I want it to look stock.
Old Nov 19, 2010 | 03:51 AM
Engine: 3.8, 3.4
Re: MSD OR ACCEL ??
If you can, spring for powdercoating instead, paint will tend to chip, especially if you don't prep it right, take if from someone who's been there.
Old Nov 19, 2010 | 03:39 PM
Car: Camaro
Re: MSD OR ACCEL ??
Tom P
when you put the MSD 6AL box
could you feel i difference ?
btw i got the msd coil
Old Nov 19, 2010 | 08:02 PM
Killert's Avatar
Car: 88 Firebird.
Engine: 383 HSR
Axle/Gears: 9 Bolt, 3.27:1 Diskbrakes
Re: MSD OR ACCEL ??
I just put a 6Al2 in my V6, I've noticed the feel of more torque on the butt dyno
Old Nov 19, 2010 | 08:03 PM
Engine: 3.8, 3.4
Re: MSD OR ACCEL ??
I can't wait to adopt the DIS setup on my 3.4....but first I have to finish fixing up the car and get a tuneable ECM that can also run DIS.
Old Nov 20, 2010 | 12:12 AM
RSFreak's Avatar
Car: 1985 Camaro, 1986 Trans Am
Engine: 5.0L carbed and 5.0L TPI
Transmission: TH700R4
Axle/Gears: 3.23 and 3.27 posi
Re: MSD OR ACCEL ??
I've got an MSD 6AL and a Blaster coil on my 2.8L.
Old Nov 20, 2010 | 09:30 AM
Car: Camaro
Re: MSD OR ACCEL ??
damm rs freak nice 2.8
how do you like the whole msd set up ?
nice cold air where you get it ?
Old Nov 20, 2010 | 12:35 PM
Engine: 3.8, 3.4
Re: MSD OR ACCEL ??
there is no air intake in that picture...
Old Nov 20, 2010 | 12:43 PM
Car: Camaro
Re: MSD OR ACCEL ??
if you go to his page and look at his other pics you will see it ,
Old Nov 20, 2010 | 08:33 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: MSD OR ACCEL ??
Well, since it was asked, the guys who designed our ignition systems say they're crap, but that's the way it had to be done. They also say that if not using the stock coil and going for a better one, an MSD Blaster oil filled can coil or similar should be used and that the coil should be mounted away from a heat source to help it last. Personally, I had an Accel stock replacement... It was a $45 paperweight until I finally threw it out a couple months ago. Others on here have bought Accel parts and have had nothing but problems with them (injectors).
Old Nov 21, 2010 | 02:35 PM
Car: Camaro
Re: MSD OR ACCEL ??
where should i place my coil in not next to the motor ?
drill it some where
Old Nov 21, 2010 | 02:36 PM
Engine: 3.8, 3.4
Re: MSD OR ACCEL ??
Best place imo is at the top and middle of the firewall, best place I've seen one mounted.
Old Nov 21, 2010 | 03:56 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Re: MSD OR ACCEL ??
Put the coil anywhere it's NOT 8 inches or so away from 600* (or so) exhaust parts... Especially if you plan on running headers in the future.
Old Nov 22, 2010 | 10:40 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Re: MSD OR ACCEL ??
After I put my 6AL box on, the only real difference I noticed was that my car took slightly longer to start (about 3/4 second of "crank time" then a half-second). It's definitely higher voltage because it melted my non-brass rotor button (now I have to use MSD's cap/rotor) and chews up the plugs faster. If your ignition system's in good shape already you probalby won't notice a difference.
RSfreak, nice heater-only box!
Old Nov 22, 2010 | 02:27 PM
Killert's Avatar
Car: 88 Firebird.
Engine: 383 HSR
Re: MSD OR ACCEL ??
I noticed that too, its starts right up but it's noticeably longer
Old Nov 22, 2010 | 03:36 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Re: MSD OR ACCEL ??
Hey cool I thought I was all alone! Glad to hear it happened to someone else too.
Old Nov 22, 2010 | 04:33 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Re: MSD OR ACCEL ??
These are the only 4 coils you should use.
NAPA IC12
MSD 8200
Summit G5215
Carquest 26189
I run the G5215 with my MSD, they are the only coils approved by Dave Ray that pass his rigrious spin test, he doesn't consult for pro race teams cause hes a boob
Old Nov 22, 2010 | 04:41 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Re: MSD OR ACCEL ??
Nice to see you crawl back out of the wood work
I noticed no change on start up but my MSD box is on a carb V8 which usually takes 2 tries till the manaul pump get gas moving. So it could be the same, dunno but maybe its a matter of charge time? MSD don't fire till it juiced up. Maybe turn the key on and wait a sec before starting???
like turing on a stereo, there is a slight delay till the amp juices up and works, yet the speakers not on the amp are instant on.
Old Nov 22, 2010 | 07:36 PM
eric17422001's Avatar
Car: 3
Engine: inboard
Transmission: underfloor
Re: MSD OR ACCEL ??
Hey Tom P and I both logged in and posted within a week! Where ya been Tom?
I had a Mallory 6A box on my wife's '91 3.1 RS and noted no difference, I did it mainly as I got it fairly cheap off Ebay and wanted to see everyone's claims. I found nil. Mileage etc the same. Now, when someone takes a car that needs plug wires, cap etc and they replace it all and say "WOW what a difference!" It ain't an apples to apples comparo if ya know what I mean.
Now in Mathew's case on a carburetted vechicle- yes, they do make more of a difference in starting and bottom end smoothness as they make up for some fuel mixture inefficiencies of the carb setup.
In my 355 powered S10 I run a Mallory HEI only as my stocker was worn out and the Mallory replacement was on sale. But no multi spark boxes. I have run a 13.22@103.9 with that truck and am fairly convinced that until you need rev limiting capabilities or some sort of boost or nitrous spark retard the good 'ol GM module and distributor are more than adequate to do the job.
Old Nov 22, 2010 | 07:53 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Re: MSD OR ACCEL ??
That made it worth it, cold starting is 100% better, once the choke is set right [I use a full manual choke] it runs like a FI car when cold [engine and outside temp wise]. No more rev'in to blow it out so all the plugs fire good and needing to let it warm up a min, would get pissy sometimes if not.
Other then that no notice in MPG or anything. Id do it again though.
A tip Summit boxes are just Mallory boxs with a Summit sticker n a cheaper price. Though MSD is king for a reason.
[ Side note, I hate when someone uses my full name, Its means they know to much ]
Old Nov 23, 2010 | 09:26 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Re: MSD OR ACCEL ??
Hey Eric & Gumby- it's always glad to see some familiar screen names! I just got the Firebird started after 2 years of "dead fuel pump", after changing the fuel pump and draining old/bad gas (and other various pre-startup-procedures), the engine fired right up. Luckily it wasn't seized- although the alternator was. And the Interstate battery sat dead for all that time, 1 day on my charger and it's back to good again. Funny how time slips away so fast! G that notchback looks great on there. Did you mold those hood scoops into the factory hood?
Old Nov 30, 2010 | 11:21 PM
RSFreak's Avatar
Re: MSD OR ACCEL ??
Thanks! My engine was a bit cleaner when that pic was taken. I made the CAI mostly out of Spectre stuff from Schucks and Autozone. I cut a 4" hole where the evap canister used to be and mounted the filter below.
Heres a better pic of the completed CAI. (sorry to jack this thread) ;-)
Old Nov 30, 2010 | 11:50 PM
RSFreak's Avatar
Re: MSD OR ACCEL ??
Thats what you get with a no-option car! My buddy and I snag those boxes from the junkyard whenever we see them as people always seem to want them.
Old Dec 1, 2010 | 08:37 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Re: MSD OR ACCEL ??
I found one once- and yes I have it, but I didn't take the squirrel cage (left it on the fender). Later on I found out the squirrel cage is smaller... So if I ever use my heater-only box (I lost my a/c years ago in an accident, condensor burst, so I never put it back in), I'll have to rig up a spacer for it. And I thought of it later that I should've grabbed the heater-only control head too. Oh well.
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
meeklay812
Oct 1, 2015 03:46 PM
86CamaroDan
Sep 29, 2015 10:08 PM
efiguy
Sep 27, 2015 01:30 PM
