How much to replace ECM in my 88' bird?
Old Jan 1, 2011 | 09:10 PM
jrlk2005's Avatar
Just looking for an estimate. Thanks
Old Jan 1, 2011 | 09:37 PM
84redta's Avatar
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
Re: How much to replace ECM in my 88' bird?
i can send you one for $20 plus shipping. i just need your zip code and the 4 digit code of the original ecm to ensure i send the correct one for your v6. also auto or stick?
Old Jan 1, 2011 | 11:10 PM
jrlk2005's Avatar
how do I find that code lol? And its a 5 speed. Thanks! Will this solve my slow starting issue?
Old Jan 2, 2011 | 08:10 AM
84redta's Avatar
to find the code on the ecm, drop the passenger foot panel under the dash, and drop the two ecm bolts, its all the way to the right under there. once dropped, find the i believe 10 digit part number and let me know what it is. ignore the 4 digit code. if the ecm isnt supplying signal to your fuel pump and the fuel pump is waiting for the oil pressure switch to activate it then yes. it will. my 88 v8 bird needed a new ecm when it would do just that, not supply a fuel pump request, and once replaced, the car started as it should. as long as you have diagnosed your fuel system properly. then yes this may very well completely fix your problem.
Old Jan 2, 2011 | 02:38 PM
bl85c's Avatar
Car: '85 maro
Engine: In the works...
Transmission: TH700 R4
Axle/Gears: 3.73 posi
It's a 1227302. When was the last time you replaced your fuel filter?
Old Jan 2, 2011 | 05:31 PM
FireInMe17's Avatar
Car: 1990 Camaro RS
Engine: 355 Vortec TPI LT4 Hotcam
Transmission: TH700-R4
I got one from my dealership for $150 bucks with a $90 core. And the best part about it is that its brand spanking new, not a refurbished unit.
specialized
Jun 18, 2022 09:26 AM
89GTAOz
May 16, 2020 09:31 AM
355tpipickup
Aug 19, 2015 10:02 PM
Catcher55
Aug 15, 2015 07:08 PM
marcusaw
Aug 10, 2015 08:13 AM
