Terrible Shaking
Old Sep 11, 2000 | 09:17 PM
Vortex_89rs's Avatar
Terrible Shaking
When I am slowing down at about 5 mph per 3-5 seconds (moderatly fast I guess), between 35 and 30 mph, my driver side front wheel starts shaking REALLY bad. I had my knees against the steering wheel and both arms on it, and I couldn't see straight it was shaking so bad. Anybody have a clue? It kinda happened awhile ago to the other wheel, and it was an ungreased inner tie rod ball joint (it was about to come apart), but I checked everything out and it looks fine. I was going to ask you guys before I got an appointment at the local shop. Thanks for anything you can come up with!
Vman
1989 Camaro RS
2.8 V6
K&N's
700R4 tranny
Cragar Street Pro rims (old Series 30)
Pioneer DEH-P3000
Old Sep 11, 2000 | 10:59 PM
Graeme'sFirebird's Avatar
From: First one out of liberty city, burn it to the ground
i dunno if this is it, but i had that problem when i needed brakes and the metal on the pads was rubbing against the metal causing friction and rubbing =shaking? i dunno..just a thought
89 RS
305 TPI...
Previous:
2.8 s/c'd firebird
Old Sep 11, 2000 | 11:04 PM
85f-bird's Avatar
Car: 85' Firebird (Project), 92' RS
Engine: 2.8L, LS1
Transmission: 700R4, 4L60E
Axle/Gears: 3.42 Open , 10 Bolt (ukn)
you might have a bad belt in your tire. That'll cause the wheel to shake a lower speeds, but it'll be o.k. at roughly 40+ mph.
Old Sep 12, 2000 | 12:50 AM
Kevin S's Avatar
It could be a number of things,like......
a missing weight,a broken belt,bad break pads or lines to a worn out front end.
I wouldn't let it go to long unchecked.Otherwise you may not be around much longer.
I,like the rest of use do not want to see that happen.
Kevin S
10.9 @ 62.87 (1/8 mile)
89 RS 2.8(bored .030)
B&M shift Improver
B&M Mega Shifter
Perma Cool trans cooler
Accel Wires,
Ignition module,
Super coil
Streetrunner chip(for now)
Flowmaster
1.52 Roller rockers
Things You Will Never Hear a Man Say....
Damn, too bad this car isn't a four cylinder.
Old Sep 12, 2000 | 10:36 AM
CC_HotRod's Avatar
Car: 1984 Camaro
Engine: V6
Transmission: 700 R4
I agree with everyone else. You may also want to check your wheel bearings. To do this you will have to remove the rotor.
"In Racing You Have A SPLIT SECOND To Do It And Six Days To Talk About It!"
http://home.earthlink.net/~singleton052095
Old Sep 12, 2000 | 11:39 AM
The bearings, pads, and rotor are all new. I am going to be replacing the front tires soon, so I hope that is it. Since my step dad and I couldn't find anything wrong, I am just going to take it into the shop later this week. It is probably a number of things, since the car is now at 176549 miles. Thank you for all of your suggestions!
Vman
1989 Camaro RS
2.8 V6
K&N's
700R4 tranny
Pioneer DEH-P3000
Old Sep 12, 2000 | 05:47 PM
scoob8000's Avatar
Car: 95 Caprice
Engine: 5.7l LT1
Axle/Gears: 2.93
id definatly check the tie rod ends.. has it been doing it since you replaced the rotor, if so rotor could be warped.. what about the wheel bearings.. overtightening them can make them go bad fast, and not tightening them enough can cause problems too.. a broken belt would do it all the time at that speed, not just when hitting the brakes.. nor would a tire being out of balance.. how is that tire that you suspect wearing?
InfernalVortex
Apr 20, 2021 11:31 AM
92-Formula
Dec 12, 2015 10:34 PM
BrianI
Oct 3, 2015 12:57 PM
Eric-86sc
Sep 28, 2015 11:37 AM
mfp189
Sep 27, 2015 09:25 AM
