Manifold and Plenum
Old Sep 22, 2000 | 08:13 PM
Brian K's Avatar
Manifold and Plenum
I am removing hte plenum, upper and lower then I plan to remove the manifold and valve covers. How do I get hte fuel injecotr rail off so I can take the rest off...
Old Sep 23, 2000 | 12:40 AM
Kevin S's Avatar
Brian,after you take the top off the plenum there are two bolts(maybe 3)that hold the fuel rail to the lower half.After you relieve the fuel pressure remove the fuel lines by the shrader valve(or whatever the hell it is )then the fuel line to the cold start injector(if you do it carefully you can move the fuel line up and out of the way).After the bolts are out,the injectors and fuel rail will pull out of the intake as one piece.
It will take a little bit of grunting because the injectors just push into the intake.You may need to pry alittle.
Kevin S
10.9 @ 62.87 (1/8 mile)
89 RS 2.8(bored .030)
B&M shift Improver
B&M Mega Shifter
Perma Cool trans cooler
Accel Wires,
Ignition module,
Super coil
Streetrunner chip(for now)
Flowmaster
1.52 Roller rockers
Things You Will Never Hear a Man Say....
Damn, too bad this car isn't a four cylinder.
[This message has been edited by Kevin S (edited September 23, 2000).]
Old Sep 25, 2000 | 02:31 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Don't pry too hard... I cracked one of those injector "pintle-caps" by forcing the fuel rail out. In retrospect, I shoulda taken it easy... since it wasn't my motor (a blown 2.8 with a bad wristpin) I didn't care
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
Old Sep 25, 2000 | 10:51 PM
3.1 firebird's Avatar
also watch out for the fuel lines where they connect into the injector body. They have thread and you can strip them if your to rough.
Old Sep 25, 2000 | 10:52 PM
hey now that you have the top half of the motor off, why not take off the balancer and timing cover and put the Crane cam in
sailtexas186548
Feb 17, 2017 03:07 PM
Chas91Z28
Oct 22, 2015 10:12 AM
toronto formula
19
Oct 6, 2015 12:27 PM
