Is my rear end 7.5"?
Old Jan 18, 2011 | 07:14 PM
nezzie09's Avatar
Car: 1987 Camaro Sport Coupe
Engine: 2.8 MPFI
Transmission: 5-Speed Standard
I've done a search and just want to confirm.
Is my 1987 2.8l t5 Sport Coupe a 7.5" rear end? It has 3.42 gears.
I'm just asking because I found a good deal on a third member with posi and I really wanted to switch but it's for a 8.5"
Old Jan 18, 2011 | 07:29 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Is my rear end 7.5"?
you have a 7.5/7.625 ( you have a 7.625, but gears are the same between the 7.5 and 7.625, but the carrier is a littel different internally).
the 8.5 piece wont work
Old Jan 18, 2011 | 07:32 PM
nezzie09's Avatar
Engine: 2.8 MPFI
That's what I figured. Thanks.
7.5 gm auburn 26 spline posi
Will that unit fit? If not, what am I looking for to change to posi?
Old Jan 18, 2011 | 08:40 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
General info in the link to following may be helpful:
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
Old Jan 18, 2011 | 09:54 PM
nezzie09's Avatar
Engine: 2.8 MPFI
Will a 7.5/8 eaton posi 28 spline fit in my carrier if I switch my axles?
hectre13
Dec 11, 2023 08:14 AM
Warlocksirix
Sep 3, 2015 12:26 PM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
