vibration
Old Oct 12, 2000 | 03:09 PM
CaliCamaroRS's Avatar
Engine: LH0 3.1L
vibration
ok my car is vibrating like a ****. it does it a lot at idle and sometimes at low rpm speeds. all my mounts are good and so are the universal joints on the driveshaft. it feels like it's coming from the tranny. maybe it's gonna take a $hit??? please help.
Dan
100% stock 1990 RS 3.1L
and VERY slow
Old Oct 12, 2000 | 03:26 PM
RenoLB8's Avatar
My tranny did this when it was low on fluid, so check that. Also, check your sparkplugs, sometimes you'll be missing on one cylinder only through the low RPM's, but then it will kick in on the highers. Good luck.
-Reno
Old Oct 12, 2000 | 03:48 PM
Engine: LH0 3.1L
hmmm....i just had the tranny fluid changed a few months ago but i will check that and the plugs. thanks reno.
Dan
and VERY slow
Old Oct 13, 2000 | 01:07 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Another good spot is the inside of the distributor cap and the tip of the rotor... check for a large amount of carbon deposits (white). You can remove these carefully with a flat metal file, just don't round off the edges. A new cap is best...
My car had so much deposits on the cap once that it would barely run- everything else (plugs wires timing etc) was normal. That's the last time I put a smear of silicone dielectric on distributor cap contacts!!
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
69GTOby
Apr 18, 2016 02:34 PM
sac92transam
Oct 7, 2015 02:31 PM
roysatikas
Sep 22, 2015 08:15 PM
BWilcox
Sep 20, 2015 12:19 PM
InfinityShade
Sep 18, 2015 08:32 PM
