whats the difference
Old Jan 26, 2011 | 11:24 PM
alexdavis001's Avatar
Car: 1989 camaro
Engine: 383 roller
Transmission: 5-speed
Axle/Gears: posi 373
is there any difference in the crank shaft between a 2.8 and a 3.1?
is it a different stroke?
if there is a difference between the stroke could i make my 2.8 a stroker?
Old Jan 26, 2011 | 11:45 PM
AmorgetRS's Avatar
Re: whats the difference
The only difference between a 3.1 and 2.8 is the stroke.
3.0 inch vs 3.3
As far as I am aware that is basically the only difference between the 3.1 and 2.8
Old Jan 27, 2011 | 01:20 AM
Project 3.4 Camaro's Avatar
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
Difference is in the crank btw, they have the same length rods, its actually somewhat common to stroke out 2.8s by putting in 3.1 cranks, but I think you have to swap the pistons over too or else you will have interference issues if memory serves. There are other minute details where they differ, but as far as major components go, ie. heads, blocks, intakes, valvetrain, rotating assembly, its all interchangeable for the most part.
Old Jan 27, 2011 | 09:12 AM
K-slice's Avatar
Car: 91' Firebird
Engine: 3.1 LH0 V6
Transmission: Auto 700R4
Axle/Gears: 3.23 limited slip
Yeah you could, and while your tearing into the engine you could upgrade your rockers and pushrods, and put a cam in there too!
Old Jan 27, 2011 | 09:33 PM
Car: 1989 camaro
Engine: 383 roller
since there is a difference in strokes would the pistons clear the heads and valves
Old Jan 27, 2011 | 09:53 PM
Engine: 3.8, 3.4
I am fairly sure you need to use 3.1 pistons if you use the 3.1 crank, 2.8 pistons might interfere, I may be wrong though.
Old Jan 27, 2011 | 10:09 PM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
Uhg...
This is so simple and discussed to death...
To change a 2.8 to a 3.1, the parts that need to change are the crank and pistons.
Old Jan 27, 2011 | 10:11 PM
Engine: 3.8, 3.4
Well there you have it, that confirms it, he knows more about specifics than I, that or he just has better memory :P
69GTOby
Apr 18, 2016 02:34 PM
scottmoyer
Sep 20, 2015 11:54 AM
Numbah-1
Sep 12, 2015 08:57 PM
J.C. Denton
Sep 8, 2015 05:35 PM
greenyone
Sep 2, 2015 03:39 PM
