what else has one
Old Oct 19, 2000 | 12:25 PM
82birdman's Avatar
what else has one
what other vehicels have the 2.8 v6 rear wheel drive engines. I need a manifold and crank to rebuild one that I have and I was wondering
Old Oct 19, 2000 | 12:34 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
As far as I know, only the GM Blazers used the RWD 2.8. Won't a FWD 2.8 crank work?
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
Old Oct 19, 2000 | 08:40 PM
85f-bird's Avatar
Car: 85' Firebird (Project), 92' RS
Engine: 2.8L, LS1
Transmission: 700R4, 4L60E
Axle/Gears: 3.42 Open , 10 Bolt (ukn)
i'd also think that crank would work. Now, i've never paid much attention to the FWD version, but is the intake mounted in the same direction, but there's a bellow in the pipe which moves it to fit teh fWD application?
Old Oct 19, 2000 | 10:12 PM
Kevin S's Avatar
front wheel drive 2.8 will fit a rear wheel drive 2.8
http://www.camaroforum.com/
http://v6fbody.com/
http://nethirdgen.org/
http://clubs.yahoo.com/clubs/tristatecamaro
[This message has been edited by Kevin S (edited October 19, 2000).]
Old Oct 23, 2000 | 06:40 AM
82birdman's Avatar
I an not sure whether a fwd would work, that is the reason I asked you guys because I don't know
Old Oct 23, 2000 | 11:28 AM
Kevin S's Avatar
When I rebuilt my engine it was knocking.Not to bad though.When we pulled it apart the crank had some light scratches.I was worried that I would have to have the crank turned alot.I didn't want to turn it more then .0010 of an inch.
I had a crank from a FWD 2.8.I called NAPA about the difference.They told me the cranks are the same.Several other parts stores around here told me the same.
http://v6fbody.com/
[This message has been edited by Kevin S (edited October 23, 2000).]
Old Oct 24, 2000 | 06:53 AM
82birdman's Avatar
thanks for your help
