torq specs
Old Jan 31, 2011 | 12:31 PM
whiteboycv67's Avatar
Car: 90 Firebid
Engine: 3.1
Axle/Gears: 10 bolt posi w/4.11s
torq specs
i need torq spec for 90 firebird 3.1 head bolts ??
Old Jan 31, 2011 | 05:44 PM
AmorgetRS's Avatar
Re: torq specs
Here is what I found:
Torque sequence --------- | 6 2 3 7 | | 5 1 4 8 | --------- Step 1: torque in sequence to 33 Ft/Lbs Step 2: turn an additional 90 degrees Recheck final torque in sequence.
The bolts are TTY, so you should replace them.
Old Jan 31, 2011 | 08:29 PM
micktroup2's Avatar
Car: 1991 Z28
Engine: 5.7 TPI
Re: torq specs
Anyone know the torque specs for intake manifold bolts for the 3.1?
Old Jan 31, 2011 | 08:42 PM
Pillsbry10's Avatar
Car: 1992 Camaro RS 25th Anniversary
Engine: 3.4L v6 with a t3/t4 Turbo
Transmission: T-5 Conversion
Axle/Gears: 3.23 SLP Limited Slip
Re: torq specs
Lower intake manifold, 19 Ft/Lbs,center intake manifold, 15 Ft/Lbs(to torque bolts & nuts, start in center using crisscross pattern)
Old Feb 1, 2011 | 10:24 AM
Car: 90 Firebid
Engine: 3.1
Re: torq specs
im only retorqueing them not removing yet anyways im trying to avoid doing a gasket with retorq and some k seal just so i can sell the car for $700
gord327
Oct 3, 2015 01:25 PM
mfp189
Sep 27, 2015 09:25 AM
wstephan96
Sep 25, 2015 04:28 PM
brockerboy
Wheels and Tires
Sep 17, 2015 03:59 PM
angel2794
Sep 8, 2015 06:22 PM
