I smell a bad mix. comming out of my exhaust
Old Nov 2, 2000 | 07:28 AM
Horst's Avatar
Car: Firebird
Engine: 3.1 L
Transmission: auto
after putting in new headgaskets my bird was not running as good as before, no power, no speed,I set the timing on 20° and it was much better, but I have this high emission and high fuel usage.
thanks for any ideas
Old Nov 2, 2000 | 12:59 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Since advancing the timing helped, maybe the distributor's 180 degrees off? #1 cylinder is the frontmost passenger side- usually it's the frontmost left side.
Could the heads need to be re-torqued?
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Nov 2, 2000 | 01:19 PM
Horst's Avatar
Car: Firebird
Engine: 3.1 L
Transmission: auto
thanks TomP,
I'll check this out.
Horst
Old Nov 5, 2000 | 09:19 AM
Horst's Avatar
Car: Firebird
Engine: 3.1 L
Transmission: auto
would the motor run with the distributer 180°off?
it's 20° in advance and runs pretty good, but I smell this unburned gas comming out of the exhaust.
The torque is 91 lbs, do I have to retorque it anyway?
www.marion-becker-nidda.de
91 Firebird 3.1
Modsynomax stainless
Old Nov 5, 2000 | 04:33 PM
scoob8000's Avatar
Car: 95 Caprice
Engine: 5.7l LT1
Axle/Gears: 2.93
hrmm yes a motor would run 180 out, ive done it before, but it will barely idle muchless be driveable.. double and triple recheck your firing order.. do a quick compression check too.. how does the engine idle, rough at all? backfiring? etc..
Old Nov 5, 2000 | 05:15 PM
Horst's Avatar
Car: Firebird
Engine: 3.1 L
Transmission: auto
engine runs great, everything seems o.k.
biside the high fuel usage, smelling out of the exhaust.
Old Nov 5, 2000 | 05:16 PM
Horst's Avatar
Car: Firebird
Engine: 3.1 L
Transmission: auto
eightsixseven
Dec 16, 2024 01:50 PM
Vintageracer
Jan 10, 2020 05:33 PM
db057
Aug 22, 2015 08:17 PM
midias
Aug 22, 2015 01:42 AM
