tranny does not shift in third gear...
Old Oct 26, 2000 | 01:57 PM
Horst's Avatar
Car: Firebird
Engine: 3.1 L
Transmission: auto
when I hit the floor speed goes to 55 and stays, it does not shift in third gear, have to lift my foot a little than it works.
any ideas ?
Old Oct 26, 2000 | 02:04 PM
Vortex_89rs's Avatar
This happened with my car, but going from 2nd to 3rd. I thought it was a vacuum problem, but all I did was readjust the TV cable and now it shifts fine.
Vman
1989 Camaro RS
2.8 V6
K&N's
700R4 tranny
Cragar Street Pro rims (old Series 30)
Pioneer DEH-P3000
1969 Camaro SC
350 HO from a Vette
Turbo 350 tranny
In the process of being restored
Old Oct 26, 2000 | 03:17 PM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
Yes, adjust the TV Cable and see if that works.
Looking For:
87 IROC-Z 350 TPI
84 TRANS AM 305 H.O.
Old Oct 26, 2000 | 05:29 PM
85f-bird's Avatar
Car: 85' Firebird (Project), 92' RS
Engine: 2.8L, LS1
Transmission: 700R4, 4L60E
Axle/Gears: 3.42 Open , 10 Bolt (ukn)
my bird used to do that, but only when my tranny fluid was real low, (i've got a leak.) also, my car never shifted at 55mph into 3rd, it was always around 70-75mph. So, you just might need to adjust that tv cable. tell us how it works
Old Oct 29, 2000 | 08:54 AM
Horst's Avatar
Car: Firebird
Engine: 3.1 L
Transmission: auto
thanks guys, but how do I adjust the TV cable, i can't find anything to adjust with, I mean no screws or so and there are 3 cables at the throttle, 2 are plastic covered
and 1 is a steel wire.
also I have to say is that I have new headgaskets and heads are magnufluxed, also a new distributercap. Could it be a timing problem? and is 10° over 0°o.k.?(auto tranny)
thanks for your ideas
Old Nov 5, 2000 | 05:30 AM
Horst's Avatar
Car: Firebird
Engine: 3.1 L
Transmission: auto
I adjusted the TV-cable, shifting is o.k. now.
Old Nov 5, 2000 | 05:36 PM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
At least you car will shift my car once t ges to shift into 3rd it revs up and redlines i fryed my clutches.
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
bjpotter
Oct 4, 2015 07:48 PM
racereese
Oct 3, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
