Rocker arms
Old Nov 18, 2000 | 06:13 PM
Monkie's Avatar
Rocker arms
If I got some rocker arms without getting the cam how much HP would I get? A good gain or not really? Thanks!
1992 Camaro RS 3.1L
T5 Manual 5 speed
Open Air Intake
Z-28 Exhaust
8.5mm MSD Ignition wires
TB Coolant bypass
Old Nov 18, 2000 | 06:52 PM
Dan84SC's Avatar
From what I've read and heard, going from the stock ratio to 1.6s will make a difference in power that you should be able to feel.
If you go with 1.6 rockers, get roller rockers. Roller rockers help reduce friction and really help you in the higher RPMs.
Old Nov 18, 2000 | 11:25 PM
Kevin S's Avatar
My opinion is they are worth it.But you probably won't feel a big difference.Every little thing helps.Look at it this way......when you do get a cam atleast you will have the rockers already .
http://www.camaroforum.com/
http://v6fbody.com/
http://nethirdgen.org/
http://clubs.yahoo.com/clubs/tristatecamaro
[This message has been edited by Kevin S (edited November 18, 2000).]
Old Nov 19, 2000 | 07:43 AM
Brian K's Avatar
Syxxgunnar@aol.com had 1.6's put in with out a cam and new valve springs and it was a huge mistake. Email him and he will tell ya without new valve springs at the same time you will suffer, at least in his case his car was noticably different in a bad way...
Ed1LE
Sep 30, 2018 09:14 AM
92rsvortec350
19
Oct 9, 2015 09:39 AM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
1HotZ28&SS
Sep 28, 2015 08:58 PM
