Setting Idle Speed...
Old Nov 26, 2000 | 04:04 PM
87 Firebird's Avatar
I'm planning on finally setting my IAC right. I have the directions for setting as per the thirdgen.org article, but it's been less than helpful for me. This is what I know has to be done:
1) Bridge A+B on the ALDL
2) Disconnect sensor feed on TB
3) Start car
4) Adjust setting to ~ 450 RPM
5) Turn off car
6) reconnect IAC sensor feed
7) Start car
This is all easy and makes sense to me BUT I can't find that *^%# screw to set my idle speed! Where is it on a 2.8 EFI third gen? Thanks
87 Firebird 2.8 w/!MAF/!CAT/K&N Filter/Bosch Platinum +4/Neihoff Platinum
Wires/Blue Streak Cap+Rotor/Crazy Sound System/Crazy Driver/
Old Nov 26, 2000 | 05:25 PM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
its behind the throtle body were all your cables attach to it. id say leave it every timei adjusted it i had nothing but problmes and had to rase my idle to about 1000 rpm for it to run good
Old Nov 27, 2000 | 01:35 AM
CaliCamaroRS's Avatar
Engine: LH0 3.1L
yeah, you know how to rev the engine by pulling on the throttle cable right??? the cable is attached to a metal piece that, when idle, rests against the idle SCREW. although i've heard that adjusting this won't do anything because the idle speed is computer controlled.
Dan
1990 3.1L RS
80 Series Flowmaster
It's fast(er than a 3 cyl metro)
specialized
Jun 18, 2022 09:26 AM
Street Lethal
Apr 30, 2019 12:14 PM
Andrew6.688
Dec 13, 2015 10:59 AM
bamaboy0323
Sep 3, 2015 06:07 AM
perZ
Aug 15, 2015 01:17 PM
