to 85f-Bird (go ahead and lock it even though it is somewhat tech)
OK I thought you mean t the new ones. I think the thing is back in the day you could get just about any option you wanted on a car. Like say my mom in 69 bought a Z/28 with te 302 and a M22 4-speed with 4.11 gears and had no problem getting the other limited options she wanted. On the other hand all she had to do was check another box on the order form and she could have had a different Cam and another box would give her the dual 4- barrel intake set up. Or say you wanted the Rs appearence package on the Z/28, No problem. The factory could do this then and did, because alot of dealers would put special orders in to get the cars like this. Then again I am sure that every now and then a good cam went into a engine here and there for test cars and the such. Yea and back in the late 60s opar had some damn fast cars. THoug not anymore.
86 Trans Am 355 TPI Rebuilt 700R4 with Corvette servo, modified valve body, and a B&M Torque Converter (2000 rpm stall w/ lock up), 87 350 block bored .30 with new crank, bearings, rings, and magnafluxed rods. Reworked 305 heads with 3-angle valve job. Added in the rebuild was an SLP TPI cam, BBK 58mm Throttle Body,SVO 24# injectors,MSD 6A, Hypertech Power Coil, 1.5 Crane roller tipped rocker arms, SLP Intake Runners and Port matching in upper intake including fully ported plenum, TPIS adjustable fuel pressure regulator @ 46psi, Hooker shorty style headers w/ Thermotech heat wrapping, Custom 3” exhaust with Flowmaster muffler and chrome quad tips, Hypertech Thermomaster Computer chip, K&N open element cone filter on modified MAF per TPIS specs, MSD Wires, removal of A/C hardware and a 1LE firewall cover installed. Also there has been a PST front suspension kit with Hotchkis strut tower brace
http://geocities.com/SunsetStrip/Garage/9548/kyle.html
Kills:
95 Talon TSI, 96 Probe GT, 91 T/A L98, 89 RS, 86 Mustang GT, 88 Mustang LX 5.0, 92 Thunderbird V8. couple or ricers that I think were Civics or Preludes not sure what year, 95 Celica GT-S, 94 Chevy 1/4 ton 350, one of those NASCAR F150's
Kills:
Damon
Sep 26, 2015 04:29 PM
Dragonsys
Sep 25, 2015 03:51 PM
