Wiper arms
Old Dec 26, 2000 | 09:45 PM
25thRS's Avatar
Wiper arms
Okay, so I've been touching up all the faded/worn trim on my RS. Headlight trim rings, antennae base, wheel center caps, etc.
Got her looking pretty good with one (okay, two) exceptions - the wiper arms.
I found and pulled the locking tab, but I can't get the arm off the stud. Pryed (gently) with a screwdriver, but no avail. Checked Chilton's and it said that a special tool is required (GM J-8966).
Any shadetree tricks to pop the arms, or should I just go buy the tool?
Maroon '92 RS 3.1L AT PW PDL CC Tilt
Old Dec 26, 2000 | 10:06 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
If I remember right you lift the arm, pull the locking tab, and let the arm back down on the tab. The arm will hold the tab in the open position.
This will enable you to pull the arm straight up and rock it using the long side of the arm as leverage.
It is important to lift it straight or it will bind and not come off the spline.
There is a tool but sometimes you have to do with what you got.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
GO #3
[This message has been edited by Engineboy (edited December 26, 2000).]
Old Dec 27, 2000 | 10:10 AM
CC_HotRod's Avatar
Car: 1984 Camaro
Engine: V6
Transmission: 700 R4
I used a door panel tool to remove mine (The kind that looks like a bent screwdriver), Not the window crank removal tool (the one that looks like a spatula).
You can pick these tools up at any local auto store and I think Wal-mart might even carry them.
"5 out of 4 people have a problem with fractions"
My Camaro: http://home.earthlink.net/~singleton052095
Old Dec 27, 2000 | 05:11 PM
KS91Z28's Avatar
I was able to pick up the wiper removal tool from O'Reilly's for about $5. It worked great.
Old Dec 27, 2000 | 09:08 PM
25thRS's Avatar
Thanks, guys. With the help of a buddy who wasn't as nervous about breaking my RS, we managed to pop the arms off this afternoon. Got them all painted up and I'll reinstall tomorrow.
no green
Jan 9, 2016 09:22 PM
Hal87
Exterior Parts Wanted
Nov 8, 2015 03:40 PM
LT1Formula
Oct 8, 2015 08:34 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
Hal87
Sep 26, 2015 09:26 PM
