power loss
Old Jan 6, 2001 | 01:43 PM
matlock's Avatar
Car: 89 GTA
power loss
I've got an 87 SC 2.8l and when I rev the engine it has a drizzly sound with a sort of ticking and doesnt have good throttle responce. I just put in k&n air filters, and threw in rapidfire plugs, but it didnt help. Anyone know what the problem could be?
Old Jan 6, 2001 | 04:31 PM
Horst's Avatar
Car: Firebird
Engine: 3.1 L
Transmission: auto
check the plugs and wires fore the right connection, maybe you mixed the wires.
www.marion-becker-nidda.de
91 Firebird 3.1
Modsynomax ultra flow stainless steel
Old Jan 6, 2001 | 04:39 PM
Horst's Avatar
Car: Firebird
Engine: 3.1 L
Transmission: auto
sorry, you have new plugs, I missed that.
but how did the old plugs look like, hope you still have them, check the looking of the plugs, (how they work) check the wires condition.
91 Firebird 3.1
Old Jan 6, 2001 | 04:53 PM
matlock's Avatar
Car: 89 GTA
The old plugs looked horrible, very rusted. After replacing them I thought it would be a very noticable improvement, but its not much better. My wires look okay, but maybe I should replace those? I thought it may have been the gas quality.. but it still does it with 92 octane.
Old Jan 6, 2001 | 06:13 PM
scoob8000's Avatar
Car: 95 Caprice
Engine: 5.7l LT1
Axle/Gears: 2.93
sounds like you got a bad wire that is shorting out (the ticking noise) in the dark to make it easier, watch the wires with the motor running, watching for spark jumping off the wires..
Old Jan 6, 2001 | 08:49 PM
matlock's Avatar
Car: 89 GTA
You were right. I saw sparks on a few of the wires right by the metal casing on the end of the plugs. I removed all the metal casings and no more sparks, but now my coil is shorting out it seems. Im gonna replace the coil and wires. Thanks a lot.
Old Jan 7, 2001 | 05:08 PM
JoeG-89RS's Avatar
I had a similar problem. I had a bad plug wire and it was causing an arc at my coil from the main lead to the neg treminal. The best way to find the is to run engine in a completely dark garage or outside at night.
theshackle
Sep 17, 2020 08:26 AM
formula_novice
Sep 5, 2015 03:58 AM
Warlocksirix
Aug 29, 2015 11:36 AM
sailtexas186548
Aug 24, 2015 10:11 PM
Bradsaundry
Aug 12, 2015 12:34 AM
