Roller rockers
Old Feb 22, 2001 | 10:27 AM
HotRod's Avatar
Car: 87 GTA
Engine: Eaton Supercharged 350 TPI
Roller rockers
I have some 1.6 roller rockers off of a small block chev. I think they are different than are 60 degree engines but does anyone know for sure?
86 Camaro 2.8, 92 Firebird 3.1, 1951 Chev 327, Four-wheeling hybrid.
Old Feb 22, 2001 | 10:40 AM
KED85's Avatar
Simple way to tell is to test fit them and hand crank over the engine.
I UNDERSTAND, there shouldn't be a problem at all, tho. Check coil bind, is the big suggestion, tho
How about the tach deal?
Still willing to help me out?
Dying to get your option in my hands!
PLEASE LET ME KNOW, Thanks
Chat Soon,
KED85
Karl
1985 Firebird 2.8 to 3.4 swap project for Smog Happy LA, CA
Old Feb 22, 2001 | 10:51 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Supposedly the V8's rockers won't use metric studs, whereas our 2.8's use metric. I don't know what this means, though. Comp Cams has two different part #'s for a rocker arm between 305/350 V8 and 173/191 V6, the only difference is listing the V8's as having a 3/8" stud, the V6's have a 10mm stud.
As you might know, a 3/8" socket is pretty damn close to a 10mm socket. Comp Cams includes new rocker nuts with their rockers- is the only difference the new rocker nuts? The key question is is the slot in the rocker arms for the mounting stud the same size?
Bet that's more info than you needed!
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Feb 22, 2001 | 02:29 PM
HotRod's Avatar
Car: 87 GTA
Tom, that is exactly the info I needed. KED, my e-mail has been giving me problems when I try to respond but I will still give you that tach. Jump on UPS webpage and check shipping price from cincy ohio 45233. Thanks guys.
Old Feb 22, 2001 | 05:02 PM
KED85's Avatar
Hey HotRod,
I JUST SCORED A COMPLETE DASH I NEED.
V-6 1984 Firebird, I literally ripped it outta the car! Dash was off and I just kept cracking the dash unitl I got what I needed, the whole thing!!
As I was walking out, I found the 4 hole dash cover I also needed, sitting in the back hatch of another car.
I may be going back for a fender, too!
I've been stripping it as I type this.
I found several Camaros in the yard, too, and the tach circuit board will not work.
Will you still be a buddy of mine ?
Chat Soon,
KED85
Karl
KO1
16
Oct 15, 2015 05:00 PM
Agent507943
Firebirds Wanted
Oct 2, 2015 07:18 AM
92projectcamaro
Sep 29, 2015 07:07 PM
dusterbd
Sep 29, 2015 08:40 AM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
