Is my sterring wheel gonna fall off?
Old Feb 25, 2001 | 01:27 PM
RenoLB8's Avatar
I've got about 2-3 inches of vertical play in it, and now it started making a creaking noise, like maybe it's rubbing against the plastic housing right by the ignition. I know the exact problem, it's because the bracket for the tilt control is loose, but I don't have a wheel puller available to me right now. Is there any way it will actually come off, or did GM design it a little better then that? Thanks ahead guys.
-Reno
'88 Firebird LB8
"Cerberus"
http://www.angelfire.com/il/Firebird28/index.html
Old Feb 25, 2001 | 06:01 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
Yes, it will eventually come off in your hands. (have seen it happen)
See the tech articles section about how to tighten it up.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
R.I.P. #3
My favorite quote about D.E. "He can see air"
[This message has been edited by Engineboy (edited February 25, 2001).]
Old Feb 25, 2001 | 07:09 PM
Joe_L's Avatar
Car: 1995 Z28
Transmission: Built 4L60E
Axle/Gears: 3.23's - Limited Slip
Reno,
Is it really stiff to steer?
My last car, well it became stiff to steer and I thought it was the rack going so I drove it until I could get one out of a local car...well one day I pull into one of the fellows driveways who I drove to work, and the steering let go, it wasn;t the rack at all, it was the nuckle joint under the dash that let go...it would have been a nasty site if it had of let go on the highway...
1987 Firebird
2.8L Auto
T-Tops
Fresh paint
No mods yet...
My site http://www.camaro3rdgen.20m.com
Lanz06
Sep 14, 2015 07:16 PM
Stryker412
Sep 7, 2015 09:11 AM
FormulasOnly
Sep 6, 2015 10:42 AM
WickedBowtie
Exterior Parts Wanted
Sep 5, 2015 04:58 PM
greenyone
Sep 2, 2015 03:39 PM
