MPFI harness
Old Mar 3, 2001 | 08:45 AM
Lov2xlr8's Avatar
MPFI harness
who knows what each wire is coming off the fuse block connector?
Old Mar 3, 2001 | 11:22 AM
KED85's Avatar
Cheapest help is the Chiltons books.
Several easy to use pics thru out the book.
What's the problem?
When I swapped my 2.8->3.4, most of the wires and such, fell back into place, from where I removed it.
I only identified the 6 fuel injectors like one would do changing plug wires
Chat Soon,
KED85
Karl
1985 Firebird 2.8 to 3.4 swap project for Smog Happy LA, CA
Old Mar 3, 2001 | 05:36 PM
Lov2xlr8's Avatar
well, im doing a six to 8 swap, my 305 is in, but the connectors are different at the fuse block, so I need to know what is what on the six harness
Old Mar 4, 2001 | 10:32 AM
KED85's Avatar
Hit the wrecking yards for your desired harness.
That may be the easiest and most reliable way to go.
Second choice is to send me an address and I can xerox some pages from HLEMS book & MOTOR electronics book for a 1985 Firebird example.
You can also buy the harness, too.
How about going to a local GM dealer and seeing if one of them would let you borrow the HELMS book for your car, and xerox what you need? Give him a six pack or lunch.
Chat Soon,
KED85
Karl
KO1
16
Oct 15, 2015 05:00 PM
92firebirdchris
Exterior Parts Wanted
Oct 1, 2015 01:38 PM
rs_z28_vert
Sep 30, 2015 09:47 PM
z28joe2
Sep 28, 2015 05:54 PM
Eric-86sc
Sep 28, 2015 11:37 AM
