WHO WANTS POSI???
WHO WANTS POSI???
I know, it's technially limited slip, but everyone calls it posi anyways. Figured I'd share this with you guys. I'd do it, but I'm in the midst of buyin a shifter plate, pull down hatch motor, fog lights, power window motor, keyless entry, and remote start...so, i'm out of cash.
http://www.slponline.com/view_produc...TNUMBER=64501T
This will work in your car, as long as you have 28 splined gears.
From: First one out of liberty city, burn it to the ground
yea... just be sure and check the axle spline count first or ull be pissed when someone tries to install and they cant and they charge u for nothing!
1989 Firebird
2.8 v6, t5 swapped in
Ram Hi-po clutch, Cold Air, 1.6 rockers (ready to install), Lakewood LCA's, Lakewood Lift bars, 3" y-pipe, Random Tech Cat, 3" I-pipe, Flowmasters, MSd 6a, MSD Coil (Fireball in future) Accel 8.8 wires, MSD Ignition Module, 4th Gen Seats (not front yet)
" I'd rather run last in a full out race, than to NOT run at all ".
1989 Firebird
Here's an Install Page that tells you how to do it yourself.
http://www.velocityracing.com/camaro/lsd.htm
So you ccan see how easy it is to do it.
KO1
16
Oct 15, 2015 05:00 PM
