3.1 OIL LEAK
Old Mar 29, 2001 | 02:45 PM
92RSV65SP's Avatar
3.1 OIL LEAK
My 92 3.1 is leaking oil from the upper rear crankcase area and dripping down on the bell housing. Its not comming from the rear main valve covers or distributer. I found a TSB on oil leaking from the cam plug. Anyone ever heard of this or how to fix it.
Old Mar 29, 2001 | 02:52 PM
3.1 firebird's Avatar
not sure how to fix it, but thats going to be a bitch because of the location. Maybe TOmP knows.
1992 black 3.1 V6, auto, T-tops.
16flat@85.6 "order of the cacti"
Old Mar 29, 2001 | 09:46 PM
Camaro_hunter_d's Avatar
I know how this is fixed and it is a pain...I recently replced my clutch(I am lucky to have a 5 speed) and I noticed that the cam button seal was leaking. There is a speacial gasket that you HAVE to buy. DO NOT USE RTV, PLAN CORK OR COMPRESSED CADBOARD FOR A GASKET!!!!!IT WILL BLOW OUT AND YOU WILL WASTE YOUR BEARINGS!!!!!!.
You do need this special gasket beacuse it has 3 different layers of sealing gasket with metal plates between them. When you get your tranny dropped and the button back off and the new gasket replaced you tighten it until the plate is almost flush to the block. close to 30 foot pounds pressure on the retaining bolts.
Hotrodboba400
Dec 10, 2019 07:07 PM
gta892000
Aug 11, 2019 11:16 AM
tgp1990
Sep 4, 2015 06:24 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
