Exhaust is blue....how do I fix it?
Old Mar 30, 2001 | 11:27 PM
RS'er's Avatar
How can I fix it? I think blue means your burning oil. Funny,today I could have sworn it was white too when my friend was taking off into 1st... How hard will it be to fix?
I'm the proud owner of an '89 Camaro RS w/ 70k miles and a 5 spd manual.
"CAMARO:
The only thing close to it is its shadow."
Old Mar 31, 2001 | 02:14 AM
Graeme'sFirebird's Avatar
From: First one out of liberty city, burn it to the ground
i had that happen, but it was my MAF...i got lucky
1989 Firebird
2.8 v6, t5 swapped in
Ram Hi-po clutch, Cold Air, 1.6 rockers (ready to install), Lakewood LCA's, Lakewood Lift bars, 3" y-pipe, Random Tech Cat, 3" I-pipe, Flowmasters, MSd 6a, MSD Coil (Fireball in future) Accel 8.8 wires, MSD Ignition Module, 4th Gen Seats (not front yet)
" I'd rather run last in a full out race, than to NOT run at all ".
Old Mar 31, 2001 | 07:41 AM
RS'er's Avatar
My timing is prolly off cause my car was dieseling yeserday... Think maybe a full tune up would help me? Or do I have a problem thats gonna need an engine break down?
Old Mar 31, 2001 | 09:38 AM
FBODY-ADDICT's Avatar
Do this, when the car is cold, put your finger in the exhaust pipe and feel the inside, if its gooey and slippery you're burning oil, also just check your oil, does it look like chocolate even though you just had it changed? These are just a couple of do it yourself tips so you know whats up befor you take it to the shop.
Old Mar 31, 2001 | 11:25 AM
KED85's Avatar
Is the blue exhaust on start up or acceleration?
If it's on start up, heads are worn, need to swap for a rebuilt set.
If it's acceralation, it's a worn bottom end.
Need an engine swap to fix.
The mechainc will charge about $60 for the look-see.
You want to ask if he can perform a "leak-down" test. Which will definetly show & confirm if it's top end or bottom end. A compression test will "show" you need work, not truly confirm which parts of engine are worn the most.
How does the engine run? Have you pulled spark plugs, lately, to see what may be shown by your own eyes? Real BLACK, OILY plugs show you have problem, Houston!
Chat Soon,
KED85
Karl
1985 Firebird 2.8 to 3.4 swap project for Smog Happy LA, CA
Dyno Don
Jan 24, 2016 08:24 AM
TheTraut88
Sep 11, 2015 05:16 AM
Jackrabbit501
Sep 2, 2015 09:14 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
dyeager535
Aug 28, 2015 08:10 AM
