pcv valve location
Old Apr 9, 2001 | 12:04 PM
v6-3.1's Avatar
pcv valve location
I have a 1990 camaro 3.1L V6. I cannot find the location of the pcv valve. can someone please tell me the location?
also, do our cars have a pcv filter?
Old Apr 9, 2001 | 01:13 PM
Ovrclck350's Avatar
Old Apr 9, 2001 | 06:26 PM
v6-3.1's Avatar
thank you very much, I had a hard time finding it,
also, can you please point the location of the IAC valve?
THANK YOU FOR YOUR TIME!!
Old Apr 9, 2001 | 07:21 PM
Ovrclck350's Avatar
Hmm....can't say I know where that is on our cars. I could point it out to you on a 2.8 TBI though.
Old Apr 9, 2001 | 08:09 PM
KED85's Avatar
This one I can help.
ON MY CAR, it's the hose from the driver side valve cover to the fuel injection system.
it allows the fumes to vent thru the engine, twice.
Block it & you have extra oil leaks from internal pressure.
I know about this.
I put the wrong PCV valve on my Wife's 1968 Camaro, only a in-line 6.
Extra oil leak city. Right PCV, way less leaks. Way less.
Chat Soon,
KED85
Karl
1985 Firebird 2.8 to 3.4 swap project for Smog Happy LA, CA
Old Apr 9, 2001 | 08:30 PM
KED85's Avatar
That hooks up to the hole by the base of the distributor. It's connected by a hard plastic tube. The hose to the intake is odd size. I had to buy a 1/2 sized hose to reconnect my PCV set up, the old rubber hose was shot.
I took up extra spacing with electrical tape. Worked perfect, cured another possible vacuum leak.
Hose wore out from the oil leak at the distributor base from that joke of a rubber seal gasket on the shaft.
Use a small block chevy distributor gasket to cure that leak.
Chat Soon,
KED85
Karl
Old Apr 10, 2001 | 09:46 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
The IAC valve is located on the passenger side of the throttle body, at the top. From Overclck's pic, the IAC's butt points towards the alternator.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Jorlain
Oct 8, 2015 01:57 AM
86CamaroDan
Sep 29, 2015 10:08 PM
New2Chevy
Sep 28, 2015 12:35 AM
WickedBowtie
Exterior Parts Wanted
Sep 5, 2015 04:58 PM
