post your V6 1/4 mile times.....
Old Apr 7, 2001 | 01:34 PM
SkyF41's Avatar
hey guys post your times i want to see how fast some of you are running, come on.
Old Apr 7, 2001 | 04:44 PM
Ovrclck350's Avatar
I suppose this can be tech. list your mods too.
Fastest at track-17.2@77somethin or another
Fastest Gtech-16.4@88.2
Mods in sig.
Smile, you're in my rearview I'm joking, I have a v6.
Respect My Authoritaw {Cartman Voice}
See pics @ Billy's Firebird
92 Bird 3.1L Auto--Best $750 I ever spent....DRIVE IT LIKE YOU STOLE IT!
Kills:93 Mustang LX (Before Mods),98 or 99 Dodge Stratus (tough one, edged out at 40),92 Camaro RS 305 TBI-Not too fair, his fuel pump went out 2 days later. Nice car, but not running right. 97+ Honda somethin or another...modded....kept at my door the entire way
Close Calls-94 Grand Am 3.1 V6, 92 Cavalier 3.1 V6
01 Porsche 911 Turbo (Had em till first gear)
Mods-Jet Stage 2 Performance Chip, Accel Cap/Rotor, Accel 8.8 MM Wires, Accell Coil, AC Delco Rapidfire Plugs, Dynomax Catback, K&N
AIM name OVRCLCK350
Best LOUSY Run...17.263 @ 77.79MPH
In a Dog Eat Dog world, I STILL go after tha cat.
Old Apr 7, 2001 | 05:02 PM
steven's Avatar
mods and best ET at track running 220* off the line
------------------[*]191(3.1)V6 1992 Pontiac Firebird[*]K&N fiter with custom Ram air[*]Flowmaster Exhaust w/ 3" tips[*]Pioneer reciver[*]kenwood 4x6's[*]sony xplod 6x9's[*]1 kenwood 12" powered by a 300 watt jenson amp[*]-----------[*]Best 1/4 ET as of Now[*]17.7110 @76.01www.geocities.com/my_92firebird
Old Apr 7, 2001 | 05:03 PM
steven's Avatar
oh yea, and it was my frist time to race my car.
Old Apr 8, 2001 | 09:08 PM
3.1 firebird's Avatar
16.0 at 85.6mph. I couldnt get traction though, but when I do I will be hitting 15's.
3.73 open rear,crane2030,intake,shiftkit,catback,headers,pulleys,
Old Apr 8, 2001 | 10:31 PM
20-psi's Avatar
12.42 @111.25 - mostly stock, chip and K&N filter. I will be going to track after the breakin period once the car is put back together. New mods include head work, new exhaust, 40 lb injectors, TA-49 turbo and other stuff.
What do you think I should run? 11.50's @122?
Pete
Old Apr 8, 2001 | 10:59 PM
kiztope's Avatar
Car: 92 Formula
Transmission: A4
<font face="Verdana, Arial" size="2">Originally posted by 20-psi:
Pete
</font>
lol... You cheat!!!
Heck yea, you should be running 11.50's... How could you?
http://kiztope.50megs.com
92 Rs 3.1/T-5
Its slowly but surely coming along....
AIM : Theonekiztope
ICQ: 8787542
Planetarion: 3GFB kiztope of kiztopia-Camera-92RS-A (33:6:14)
"If it can be better than it is, make it so!" Leon Calrinsky (00)
Old Apr 8, 2001 | 11:38 PM
Camaro_hunter_d's Avatar
I would have to imagine that I would run close to high 14's-low 15's with the few mods I have. and the 5 speed helps alot. I have a K&N, 1.6 rockers, cam, crank case evac system.
I can spin the rear wheels to 20 MPH and then hit second and spin for a few secs then chirp third. and this is not a clutch spin/dump. straight pedal to the floor.
I can get 0-45 in about 4 secs, holding 1st, hit 2 and holding sec till 50-60 dump 3rd and go to 75 then 4th and hit 90ish then top out and roll into 5th...And I do not relese the gas when shifting..helps a good acceleration jump/thrust.
Old Apr 8, 2001 | 11:45 PM
AlexJH's Avatar
Engine: 5.7L V8
I haven't looked at this yet, but I'm wondering if there is a way to run the belt without the alternator or power steering pulleys (and any other unnecessary ones) to reduce the drag on the system. Of course, you could only do that for a little while until the battery drains but for a run down the track it might be worth it.
Would it work, or be worth the trouble?
Old Apr 8, 2001 | 11:49 PM
Ovrclck350's Avatar
I was wondering about that too, it'd be kinda cool to do if you can. Take a look at your engine, and see if you can see a pattern that'll circle the water pump, crank and your belt tensioner without circling anything else. You'd also have to make sure they're rotating the right way too.
Hey, Camaro Hunter. Post a timeslip. I believe your car always FEELS faster than it really is anyways. Especially when you're either drunk, or using a watch as your stopwatch.
Old Apr 9, 2001 | 09:22 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Alex, good idea, you might get an extra HP or two. You named the two biggest offenders... do you have the serpentine belt system? You'd need to run a shorter belt, and try to link it between the crank, idler, a/c (acts as an idler pulley when the a/c is off) pulley, and water pump.
If you have the V-belt (82-86) system, you'd just remove the belt driving the alternator, and remove the belt for the power steering. Leave the last belt (a/c) on to connect the crank to the water pump.
My best run lately? (sigh) 17.04 @ 77.9 mph. [edit] I forgot we were posting mods... here's my e-mail signature. And by the way, "SC" means "Sport Coupe", not supercharger.
-Tom P
1986 Firebird SC: 2.8l v6, 2nd rebuilt 700r4, 3.73/posi/disc swap,
MSD 6AL box/Blaster/8.5mm wires, Splitfire plugs, Accel cap/rotor,
Summit gauges/remote trans filter, !TB, drilled 160 stat,
ADS Street chip, Cloyes roller timing chain, custom intake w/K&N,
B&M Megashifter/Supercooler/Stage 2 Shift kit/Overdrive sleeve,
Dynomax 2.5" hi-flow cat/super turbo, Energy Suspension bushings
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
[This message has been edited by TomP (edited April 09, 2001).]
Old Apr 9, 2001 | 09:56 AM
RenoLB8's Avatar
Actually, if you pop your serpentine off at the line, and your engine is cold anyway, you've got like 15 minutes or so before you'll come bear overheating, I've heard a lot of the real competitive guys do this. Just ditch your belt before you run. Of course, to keep your engine cool enough, you'll have to like push it through the lanes or something...
-Reno
Old Apr 9, 2001 | 09:43 PM
Sorry ovrclck350 right now I only road race and I beat out the 8s every time(they can't seem to hold the RPMs that I can). But after a few more mods I will take my car to the strip to see what it can do. I am looking into fabbing my own haders and maybe making a single turbo header...I dunno And by the way I use my cdplayer as a time reference...LOL
And pulling the serp belt to get more HP is LUDICROUS It is totally pointless. You might(MIGHT) get 1 hp at the most. And running doem the battery even for that short a time is damaging. You do realize that the power steering and alt belt combined use maybe 5 percent drag on the belt right?.
Old Apr 9, 2001 | 09:54 PM
SkyF41's Avatar
come on all you v6 owners post your times, i have a stock v6 so its slow but i want to see your guys times so i can see how fast i can get it going with some mods.thanks.
Old Apr 10, 2001 | 09:44 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Thanks for the info, Reno!
Companies like Moroso also make that electric water-pump drive system; that could probably be hooked up (and removed again) easily at the track. The last electric water pump I heard that was good enough for street use was the Meziere brands (over $300).
I don't think pulling the serpentine belt off is ridiculous; does that mean that installing underdrive pullies is also ludicrous? Pulling off the serpentine belt would give more power than putting on underdrive pullies, yet people do the pullies all the time- AND feel an improvement! It stands to reason that running without the belt at all would yield a greater improvement.
However, it wouldn't give an accurate "on the street" example of a 1/4 mile time. ---Of course, with everyone emptying their windshield fluid bottles, removing their spare tires, and ditching their stereos for a track run, who really does 100% represent an "on the street" time?
Old Apr 10, 2001 | 10:21 AM
raging86's Avatar
car craft did a test on cheap mods like that. when they ran without a belt they went slower cause the alternator wasn't charging and the ingnition voltage dropped.
86 IROCZ
T-Tops
700R4
305 TPI
3.23 gears
shift kit, manual TC switch, manual fan switch, flowmaster exhaust with edelbrock TES headers& hollow cat, gutted MAF.
Linson
Oct 24, 2025 02:00 PM
F-body-fan
Jan 12, 2023 01:49 PM
FormulaEngland
European Region
38
Jul 17, 2016 07:33 AM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
