Stalling problem
Old Apr 14, 2001 | 03:50 PM
1984-Firebird-SC's Avatar
Car: 2002 Grand Am GT
Engine: 3400 V6
Transmission: Automatic
Stalling problem
Over the past couple of weeks I've noticed a problem with my car. It has a tendancy to stall when the gas is un-applied. Mostly in corners (not very quicky either) but sometimes if I let off going in a straight line it will as well. This seems to happen no matter the amount of fuel in the car (full or empty). It always will restart, though it takes a lot of cranking and applying the gas pedal. Fuel pump perhaps...???
Mike Davis 1984 Pontiac Firebird
2.8L V6 LC1
Camaro Z28 mag rims
Kenwood KDC-215 CD receiver
"Oh I've seen better days
The pain of these memories I cannot drive away" - Econoline Crush "Nowhere Now"
Old Apr 14, 2001 | 09:21 PM
KED85's Avatar
Float level in the carb.
IT's real common. My S-10 Blazer does that, too.
My friend attempted to correct, got close, but NOPE.
It could be time for a total overhaul including the throttle base plate shaft. New bushings & stuff down there.
Chat Soon,
KED85
Karl
1985 Firebird 2.8 to 3.4 swap project for Smog Happy LA, CA
Old Apr 14, 2001 | 10:51 PM
michael's Avatar
Car: 1991 Formula
Engine: 6.2 383 TPIS Miniram
Axle/Gears: Moser 9" 4.11
Ked85 hate ta tell yea this but his is a 2.8 which means fuel intected no floats just pumps and injectors. It could very well be dirty injectors or the maf sensor I noticed that mine would try to stall at lights or sitting without applying gas
and when it did die it would be very hard to restart turned out to be the maf
but it might very well be your pump also
no telling the card **** is easier to trace the prob :-(
1987 Chevrolet Camaro
2.8 Ltr HO Cut air boxes K&N Filters Gutted Cat (Did I say gutted opps don't tell the officer)
Duel catback Exhaust With Flowmaster series 80 dual 5"X24" MONSTER Echos
225/60/R16 Mounted on 97 Firebird 16X8" Rims
Old Apr 15, 2001 | 12:29 AM
Engine: 3400 V6
Actually until 85, they were carb'd (as is my car) so he would/could be right...
[This message has been edited by 1984-Firebird-SC (edited April 14, 2001).]
Old Apr 15, 2001 | 01:52 AM
Graeme'sFirebird's Avatar
From: First one out of liberty city, burn it to the ground
try that...mpfi wasnt until 85...i had the same thing in my 77 scout, checked the carb and it was the same thing ked mentioned.
1989 Firebird
2.8 v6, t5 swapped in
Ram Hi-po clutch, Cold Air, 1.6 rockers (ready to install), Lakewood LCA's, Lakewood Lift bars, Wonder Bar, 3" y-pipe, Random Tech Cat, 3" I-pipe, Flowmasters, MSd 6a, MSD Coil (Fireball in future) Accel 8.8 wires, MSD Ignition Module, 4th Gen Seats (not front yet)
" I'd rather run last in a full out race, than to NOT run at all ".
Old Apr 15, 2001 | 08:31 AM
michael's Avatar
Car: 1991 Formula
Well cuff me and haul my *** away haha Guess I thinking of older models using what the newer ones do ie 87 oh well
Old Apr 15, 2001 | 10:00 AM
KED85's Avatar
Michael,
I BELIEVE the vehicle you are thinkng/referring to is the V-6's in the S-10 Blazers.
THOSE engines have the TBI after 1985 (starting in 1986). Then the Blazer engine went to the 4.3 size, same TBI idea, tho.
Our F-bodies had the MPFI starting in 1985 to the 1992 year.
I've had my butt handed to me also.
Won't be the last time, either.
I always hope to keep learning, or else, cover my bones, I'm dead.
My friend, removed the top of the carb (several torx screws) and apparently raised it.
For my Blazer, it worked, but on left turns it may stall. Like I said, it really needs agood overhaul, including the throttle plate shaft. Find a real good shop, if you really wnat to keep the vehicle.
In LA area, rebuilds like this go for about $120 - $200 (carb only!), because it's a lot of the right work. Take the vehicle to them, let them remove it from the car. That way, they will be responsible for all proper re-adjustment. That detail is in your favor. ALOT of crap on those engines, hoses ready to break, etc. Let if fall on their shoulders.
Chat Soon,
KED85
Karl
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
Bryan F
Aug 27, 2015 07:28 AM
Bryan F
Aug 18, 2015 02:28 PM
92camaroJoe
Aug 13, 2015 06:07 AM
