thermostat
Old Apr 14, 2001 | 03:52 PM
steven's Avatar
thermostat
this is going to sound like i know nothing about cars, well i don't know that much about my car, where is the thermostat, i'm replacing it with a 180*. pictures will help.
------------------[*]191(3.1)V6 1992 Pontiac Firebird[*]K&N fiter with custom Ram air[*]Flowmaster Exhaust w/ 3" tips[*]Pioneer reciver[*]kenwood 4x6's[*]sony xplod 6x9's[*]1 kenwood 12" powered by a 300 watt jenson amp[*]-----------[*]Best 1/4 ET as of Now[*]17.7110 @76.01www.geocities.com/my_92firebird
Old Apr 14, 2001 | 08:13 PM
Garmer's Avatar
I dont have any pics, but I am sure this will help you.
Do you know where the radiator is? If yes, proceeds, if not, oh well. Anywho, on the upper right hand side of the radiator, there is a tube that carries the antifreeze. Just follow it to where it enters the engine. And there it is. It is under a iron housing. Its hard to see on our cars, but on like older cars it is plain as day. I sure hope I helped you some.
91 RS Camaro
3.1L
Cat Back System, K&N filter,modified air box, Fastchip Stage 2, 160 thermo, Rapidfires and Bosch Wires 5 Air Horns
Stereo: Clarion Deck, 2 12' Kicker CompVR's, IX702
ICQ: 65384740
My Car ( Now w/ Stereo)
[This message has been edited by Garmer (edited April 14, 2001).]
Old Apr 15, 2001 | 12:18 AM
steven's Avatar
thanks man, i've been wondering where it was for a while. thanks.
Old Apr 15, 2001 | 12:24 AM
steven's Avatar
next i have to drane my antifreeze right, what is the best way of doing this.
Old Apr 15, 2001 | 01:21 AM
KED85's Avatar
Just remove the hose from the housing.
You'll loose so little, no need for concern.
Chat Soon,
KED85
Karl
1985 Firebird 2.8 to 3.4 swap project for Smog Happy LA, CA
Old Apr 15, 2001 | 11:08 AM
Garmer's Avatar
Like frieght train said! lol
I just stock a small bucket to pick off the little run off.
Old Apr 15, 2001 | 11:50 AM
steven's Avatar
so i have to take off my MAF and some other stuff to get to it right.
Old Apr 15, 2001 | 01:15 PM
HIX5000's Avatar
Yes remove the maf and throttle body.
Old Apr 15, 2001 | 01:38 PM
steven's Avatar
is it hard?
Old Apr 15, 2001 | 02:24 PM
CaliCamaroRS's Avatar
Engine: LH0 3.1L
you don't have a MAF to remove. and you don't HAVE to remove the throttle body. it can be done although it will be a 'lil time consuming.
Old Apr 15, 2001 | 03:31 PM
HIX5000's Avatar
You will probably spend more time trying to avoid taking off the tb then you would just removing it. It's noy very hard at all to remove.
Old Apr 16, 2001 | 01:39 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
The bolts are 13mm, if you have no metric's a 1/2" socket might work well enough.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Apr 16, 2001 | 01:43 PM
PimpRide92's Avatar
What is best? 160* or 180* for my 3.1l
1992 RS 3.1L
Trans-Go Shift Kit
B&M MegaShifter
2 12" - Kicker XPL
Eclipse 2-Channel Amp
Sony Head Unit
Window Tint 20%
Kill's:
80's Stang 4-Cyl, A few Ricers, Ford Tempo(Weak)
'91 OR '92 Z28(Dont Ask Me How) All On A Mesh Up Tranny!
Old Apr 16, 2001 | 02:02 PM
Brads RS's Avatar
A 180 is better for a V6 or V8. 160's run to cool and makes your ecm think that its cold out or somthin like that anyways it makes ya eat gas, and in the winter there is absolutly no heat in the car at all
1992 RS
Flowmaster exhaust
Hypertech power chip
180 thermo
Split fire plugs
K&N filter
Old Apr 18, 2001 | 05:45 AM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
The ecm is happier with a 180 than it is with a 160. The 160 makes the eprom think it is in "start up" mode, which wastes gas.
People think that it makes their cars "peppier", but in fact it is just giving a larger "pump shot" when you boot it. After that, you are running too rich. The stock GM memcal is too rich as it is and the last thing you need is more fuel for max performance.
I (and others) have found that an overly rich mixture seems to induce "knock retard" which kills performance. When "knock retard" occurs (and you won't hear it if the knock sensor is doing it's job), it pulls far too much spark retard out of the ecm so you end up with less effective spark advance. This often occurs when you advance your "base timing" above the stock setting. You may have added 2* of spark advance, but the ecm pulls 4* away, leaving you with 2* less effective spark advance...and a slower car.
Old Apr 18, 2001 | 09:32 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I run a 160 in the summer, and a 195 in the winter. My temp gauge in the summer always shows around 180-190.
The 85-89 2.8 MAF V6's don't have knock sensors. I'm not sure about the 90-92 SD 3.1's.
Glenn, my '86 GM book says that for closed loop operation to occur, the engine must be running for a few minutes, coolant temp must be above 75 degrees, and there must be a changing value from the oxy sensor (hot exhaust). I'd tend to believe the GM book, but you've had your hands in the prom itself- is there any truth to this?
Bubbajones_ya
Jul 6, 2024 08:32 PM
sheachopper
Jul 31, 2019 11:27 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Stryker412
Sep 20, 2015 06:59 PM
BWilcox
Sep 20, 2015 12:19 PM
