need help fast ignition problem
Old Apr 21, 2001 | 07:23 PM
SUPER CHEVY66's Avatar
Car: 92 camaro, 06 trailblazer ss
Engine: 5.0 tbi, 6.0 ls2
Ok today i did a tune up cap, plugs, wires and a rotor and when i put everything back together it wouldnt start it would crank over fast and then bog for a few seconds and then do the same thing whats going on and do i have to use dielectric grease for it to start thanks David.
Old Apr 21, 2001 | 10:59 PM
Luke's Avatar
Car: '86 Camaro
Engine: 2.8 MPFI
Sounds like you may have switched some of the wires around by accident. You may want to double check the firing order.
Old Apr 22, 2001 | 01:19 AM
Camaro_hunter_d's Avatar
well the firing order on the 3.1 is real easy..123456..lol no joke...cap plug one is front right closest to the intake...then clock wise from there.
Old Apr 23, 2001 | 01:10 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
No, that's not true. The position of the #1 cap terminal can be anywhere on the distributor cap. Maybe GM put them all in the same spot from the factory, but who knows what was done to the car since then! Read my last posting in this message for the full details: https://www.thirdgen.org/messgboard/...ML/000866.html
Read my 2nd & 3rd post in this message (which I link to inside the above message) to find out how to determine which terminal on your distributor cap is for the #1 cylinder: https://www.thirdgen.org/messgboard/...ML/000850.html
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Infested
May 22, 2018 11:56 PM
Fast355
Dec 2, 2016 06:33 PM
Bryan F
Aug 27, 2015 07:28 AM
db057
Aug 22, 2015 08:17 PM
