Camaro start to fail..!
Old May 16, 2011 | 11:22 PM
fitojdj's Avatar
Car: Camaro RS 1992 25th
Engine: 3.1 L 191 cid LH0 60° Gen II V6
Transmission: Automatic
Axle/Gears: Heritage Package (RPO Z03)
I got a v6 92 camaro and it recently i changed the injectors and the car was wroking kind of lazy... also it stops sometimes.. like redlights... but works..
and one day its stops....
this is the recorded sound just before it stops....
http://dimex.comoj.com/camaro_92_fail.mp3 ...
fuelpump new...
wiring new..
there is spark... and fuel running...
circuits checked..
THANKS..!
Old May 17, 2011 | 12:11 PM
CgMcKinney's Avatar
Car: 1990 Camaro RS
Engine: Stock 3.1 v6
Re: Camaro start to fail..!
So all of this happened after you changed your injectors? Make sure they're seated properly and you reattached all of the vacuum lines attached to the upper intake.
Old May 22, 2011 | 09:51 PM
formula 89's Avatar
Car: 89 formula,92 firebird
Engine: 91 355 tpi, 3.1
Transmission: 700 R4
Axle/Gears: 342 posi,
my 92 bird with a 3.1 is doin the exact same thing, i have a new dizzy and fixins, new coil,new fuel pump(42 psi at rail) just wont start but tries
Old May 22, 2011 | 09:54 PM
CgMcKinney's Avatar
Car: 1990 Camaro RS
Check your coil, wires, and plugs.
Old May 22, 2011 | 10:36 PM
formula 89's Avatar
new coil and fairly new plugs and wires, it does have fire, also a new cat so im pretty sure it not a backpressure problem
Old May 23, 2011 | 12:12 AM
CgMcKinney's Avatar
Car: 1990 Camaro RS
Did you set your timing after installing the distributor?
And both of you need to do an idle relearn if you ever get to the point where your vehicle actually stays running...
Old May 23, 2011 | 12:35 AM
formula 89's Avatar
timing is correct,cant do in idle relearn till it starts and runs,hense the the problem wont start
Old May 23, 2011 | 08:11 PM
CgMcKinney's Avatar
Car: 1990 Camaro RS
OP: What injectors did you replace the old ones with?
Old May 30, 2011 | 10:35 AM
fitojdj's Avatar
I take out the inyectors rail to check... and one of them kept opened drowning it.... they check all my inyectors... i bought a good used one...
but when i tried sounds like it works but it shut off when i stop doing cranck!
and now sounds like the recording....
Originally Posted by fitojdj
Frozer!!!
Jan 19, 2024 04:55 PM
92camaroJoe
Jul 29, 2023 07:57 PM
Caspar
Jun 19, 2016 11:19 PM
92camaroJoe
Aug 13, 2015 06:07 AM
