Fan problem...
Old May 17, 2011 | 12:20 PM
JohnnyCamaro91's Avatar
Car: 1991 Red RS T-Tops
Engine: 3.1 v6
Fan problem...
OK, heres the situation. When I originally got my car it had two wires coming out of the dash that I had to twist together to make the fan work.
I ended up changing that by running the power wire to a fuse so that the fan would come on when I start the car.
It worked fine for about a month, until today when my windshield wipers stopped working. Checked the fuse and sure enough that was the issue. In fact the fuse was melted all to heck.
I am wondering if there is a safer more efficient "poor mans" way to rig this up. Normally I would put the assembly back the correct way, but I am low on funds at the moment.
Any would be greatly appreciated.
Old May 17, 2011 | 12:26 PM
CgMcKinney's Avatar
Car: 1990 Camaro RS
Engine: Stock 3.1 v6
Re: Fan problem...
You could just route the two wires into a switch and use it to manually power the fan.
Old May 17, 2011 | 12:51 PM
Engine: 3.1 v6
Re: Fan problem...
Im trying to avoid this, I would like the fan running always until I properly fix it
Old May 17, 2011 | 12:59 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Fan problem...
Either buy a seperate fan controller and wire it in (easy & $40 - $90), or read my second post in this thread to use a relay and get that high amperage wiring out of your fuse panel: https://www.thirdgen.org/forums/cool...ctric-fan.html
I myself run a Flex-a-lite fan controller from summit, $90 but is fully adjustable and doesnt use any of the old factory wiring/relays - best $ I ever spent.
sheachopper
Jul 31, 2019 11:27 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
BrianI
Oct 3, 2015 12:57 PM
Fanatic1074
Oct 2, 2015 03:47 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
