Fuel Presure
Old Apr 29, 2001 | 10:51 AM
gemmefire's Avatar
Fuel Presure
what fuel presure will give my stock 2.8 the best performace.. and how do you change it?
Old Apr 29, 2001 | 11:33 AM
Camaro_hunter_d's Avatar
well I have the 3.1 and to adjust it you need a high pressure adjustable fuel pressure regulator(if you have MPFI) low pressure for carb/TBI. I will say safely that usually on MPFI engines you feel a difference with 6-9 PSI more(the snap acceleration no longer bogs and hard cornering lag is gone). TBI maybe 4-5 PSI, carb is hard to say. The way that I understand how a carb works is that it takes the fuel as it is needed so if you have a clean fuel line and good mechanical pump adjusting the fuel pressure up will just spit too much fuel into the intake giving an extreme rich condition.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
mike_c
Aug 27, 2015 04:32 PM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
