timing on 93 2.8?
Old May 26, 2011 | 08:38 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
timing on 93 2.8?
my cars idleing really really low, i mean its bad enough that when i put my car in drive or reverse it wants to die, i barley have to to touch the pedal. well while reading i heard that timing needs to be set at 10*btdc with the EST wire disconnected? so i need to know if this is true on a v6 and what i need to do, please help!!!
Old May 27, 2011 | 03:10 AM
Project 3.4 Camaro's Avatar
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
Re: timing on 93 2.8?
Just try moving the dizzy cap a little bit in each direction and see if it gets any better, but that won't really affect idle speed, chances are its something else, that being said it could just be par for the course, my car idles just above stalling out as well, but mines also built up and I've still not ran it without at least 1 small issue, so hard to say.
Easiest thing to try/check is to clean out the throttle body and IAC passage, could also be caused by a vacuum leak. Biggest question is how does it sound off idle and during a rev?
Last but not least there is no such thing as a 93 2.8, 93 is the start of the 4th gens, and none of them had 2.8s, and I believe GM wasn't still using 2.8s by then in any vehicle, though I may be wrong if the s10 or some such was, but even the thirdgens stopped using it in later years and switched to 3.1s.
Old May 27, 2011 | 08:59 AM
Engine: L31 350
93 was the last year for the 2.8s in the s10s
Cleotiz
Jan 6, 2018 08:56 PM
E Rod
Aug 28, 2015 05:17 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
86Base
Aug 8, 2015 01:34 PM
