lost this little thingie!!!
Old May 15, 2001 | 09:54 PM
85f-bird's Avatar
Car: 85' Firebird (Project), 92' RS
Engine: 2.8L, LS1
Transmission: 700R4, 4L60E
Axle/Gears: 3.42 Open , 10 Bolt (ukn)
yeah, i was under the hood yesterday, and i accidently pulled off this little clip. It's on the side of the TB where the Throttle is located, it was connected to the bottom end of the throttle. Well, when the little thingie popped off it fell somewhere in the maze of engine parts. And, there's a little slide thingie that was connected to this little clip. When the clip fell off, it allowed the slide thingie to pop out, and now when the Throttle is fully open it doesn't have this little thingie to slide on. Well, the car's still acting o.k., and it shifts fine and all, but i'm wondering does this piece affect the car? i know i can go to a bone yard and pull the same piece off any other maro/bird out there,and it'll work fine, but i don't want to spend the gas yet, and i don't think that GM would put something on the car that's not needed, well, on second thought, i'm wrong about that. But is not having this little slide thingie gonna hurt the car? cause it runs fine now. thanx in advance.
Old May 15, 2001 | 10:16 PM
Camaro_hunter_d's Avatar
well you bring in st louis I know the gas gouge 1.8 something here in southern ill...anyway if you have no loose cables/wires from it then you should be fine especially if your car is still running fine....
Old May 16, 2001 | 12:07 AM
CaliCamaroRS's Avatar
Engine: LH0 3.1L
ok, your description was kinda.....well, nevermind. it sounds like you disconnected your Cruise Control. try it out and see what happens. (you do have an auto,right??)
Old May 16, 2001 | 01:07 AM
KED85's Avatar
Dan's go it right!
I used a paperclip to hold that piece on.
Has worked that way for MANY MILES
Use a thin paper clip, stainless steel type.
I have cruise on my S-10 Blazer.
You lost a "c" clip
Chat Soon,
KED85
Karl
1985 Firebird 2.8 to 3.4 swap project for Smog Happy LA, CA
Old May 16, 2001 | 10:24 AM
85f-bird's Avatar
Engine: 2.8L, LS1
Cali, you're great. That's probably exactly what it is, at least it sounds about right. So, yeah, i've now lost my cruise control. K. i was just hoping the motor wasn't going to blow up on me or anything like that.
Old May 16, 2001 | 02:09 PM
KED85's Avatar
Get a thin paper clip (or several) and twist to your hearts content. Mine is still holding up after about 4 years (on my S-10 Blazer example!)
Chat Soon,
KED85
Karl
ZZ3Astro
Aug 13, 2019 12:57 AM
djmarch
May 8, 2016 11:32 AM
86White_T/A305
Mar 6, 2016 01:48 PM
Jynx88
Oct 4, 2015 08:19 PM
3.8TransAM
Sep 27, 2015 08:37 PM
