Could this be causing my problem?
Old May 23, 2001 | 09:22 PM
Graeme'sFirebird's Avatar
From: First one out of liberty city, burn it to the ground
I was pulling the intake today to look for the vacuum leak, and i noticed hey my EGR isnt all the way on...i tried tightening it but the bolt hole is stripped. Could this be causing my stalling and none-idline condition? After this its going to paradise chevy by me to get the speedo done, all the emissions hoses and egr controller replaced, get a new MAF system and TPS, then more...so i need it to make about a 30 minute drive on the freeway. I know the emissions is causing some of the problem, but could this be causing the non-driving problem? help me!
1989 Firebird
2.8 v6, t5 swapped in
Ram Hi-po clutch, Cold Air, 1.6 rockers,Lakewood LCA's, Lakewood Lift bars, Wonder Bar, 3" y-pipe, Random Tech Cat, 3" I-pipe, Flowmasters, MSd 6a, MSD Coil (Fireball in future) Accel 8.8 wires, MSD Ignition Module, Auto Meter Gauges (Water, Clock (needed one) Fuel Pressure, and 5" monster tach) 4th Gen Seats
" I'd rather run last in a full out race, than to NOT run at all ".
Old May 23, 2001 | 10:02 PM
86Chicken's Avatar
That would surely be a suspect. When my EGR gasket went my Bird would barely idle and stall at lights all the time.
If the hole is stripped then you might want to use a clamp or something (duct tape )to try to seal the leak and see if that solves the problem. When my gasket went, all I had to do was lean on the EGR and the engine would perk right up and return to normal.
Just a thought
Dale
1986 FireBird
2.8L MPFI
Gutted Cat, No muffler (Sweet Sound)
Was 700-R4 --> Now T5
Old May 24, 2001 | 08:43 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I like the clamp idea better, but you could also wrap a ton of steel utility wire around the thing for diagnosis.
What side is the EGR stripped on? The EGR-valve-to-manifold side, or the EGR-valve-to-EGR-tube side, or the EGR-tube-to-TB side?
Usually an exhaust leak by the oxygen sensor will confuse the car... fresh air sneaks into the exhaust, and causes the oxygen sensor to sense a lean (or is it rich?) condition, so the computer compensates- and the engine runs poorly. This might be doing the same thing.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old May 24, 2001 | 09:31 AM
KED85's Avatar
Cheat
Use a stainless steel paper clip in the thread, as you bolt it down. BE surprised, it works!
If one thickness doesn't catch, try a thinner or thicker.
I'll bet you have several at home to try, before you try something else.
IT does work!
Chat Soon,
KED85
Karl
1985 Firebird 2.8 to 3.4 swap project for Smog Happy LA, CA
Old May 24, 2001 | 10:26 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Woah! Cool idea!
Old May 24, 2001 | 11:18 AM
KED85's Avatar
Tom, your response was just to get 4100 posts!!!
Someone turned me onto that trick so long ago!
I think back when I was working on our old Corvettes and the fiberglass holes, just plain ole wore out.
It really does work, sometimes!!!
I've even used this idea on suspension threads and it has held.
If it's to, to thick, try pounding it with a hammer, to try and flatten it out.
It may work!
YET, did see several 60* V-6s in the yards on Tues.
Pick a Part & U Pick Ur Part
Chat Soon,
KED85
Karl
Ghettobird52
Jul 5, 2024 11:18 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
db057
Aug 22, 2015 08:17 PM
