Quick question.
Old Jun 1, 2011 | 03:23 PM
backgammon7's Avatar
Car: '86 SC
Engine: 2.8
Quick question.
The vacum line that goes in to the FPR, what exactly does it do?
The reason I ask is my 86 2.8 MPFI runs better with it plugged than it does when it is hooked up. The car is more steady without it, before i plugged it, the car would rumble and idle well and drive ok, and then it would suddenly get quiet and sound like it still has the muffler on it and have no power, and when you put some throttle to it, it would pop and miss and not have any power.
Now it sounds better, runs better and has more power.
It has a TPI fuel pump and an Adjustable FPR. Thanks
Old Jun 1, 2011 | 05:45 PM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
Re: Quick question.
The vacuum provided by the FPR vacuum hose adjusts the fuel pressure in relation to engine load. Higher vaccum, like at idle or low throttle cruise reduces the rail fuel pressure, to maintain a delta fuel pressure of approximately 39 PSIG. The importance of maintaining this delta pressure is to have predictable fueling supply.
It sounds like your base fuel pressure may not be adjusted correctly.
F-body-fan
Jan 12, 2023 01:49 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
meeklay812
Oct 1, 2015 03:46 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
3.8TransAM
Sep 27, 2015 08:37 PM
