Help with code 34
Old May 29, 2001 | 03:18 PM
CamaroVroom's Avatar
Help with code 34
Ok i got a code 34 on the SES light which means:
34. Low voltage (high vacuum) at mass air flow sensor (or MAP sensor)
so how do i fix it and how much should it cost???
Old May 29, 2001 | 04:15 PM
ChevyGuy87's Avatar
Car: 2004 Wrangler Rubicon
Engine: 4.0
Transmission: NV3550
Axle/Gears: Dana 44s with 4.10 and air lockers
if u replace it, it'll run u around 50-60 bucks
87 Camaro 2.8 MPFI
Crane Cams 8.5 MM FireWires
Bosch Platinum +4 plugs
BFG Radial TA's (the tires are really sticky. that's why i can't peel out. I SWEAR!)
Old May 29, 2001 | 05:08 PM
Graeme'sFirebird's Avatar
From: First one out of liberty city, burn it to the ground
and if it doesnt fix it, ull be like me. I have no idea. Im probably going to live with it until i get a new engine.
1989 Firebird
2.8 v6, t5 swapped in
Ram Hi-po clutch, Cold Air, 1.6 rockers,Lakewood LCA's, Lakewood Lift bars, Wonder Bar, 3" y-pipe, Random Tech Cat, 3" I-pipe, Flowmasters, MSd 6a, MSD Coil (Fireball in future) Accel 8.8 wires, MSD Ignition Module, Auto Meter Gauges (Water, Clock (needed one) Fuel Pressure, and 5" monster tach) 4th Gen Seats
" I'd rather run last in a full out race, than to NOT run at all ".
Old May 29, 2001 | 10:35 PM
KED85's Avatar
I got a rebuit one, turned out to be bad. I got another, not a problem, since.
Chat Soon,
KED85
Karl
1985 Firebird 2.8 to 3.4 swap project for Smog Happy LA, CA
Old Jun 1, 2001 | 05:35 PM
kizz's Avatar
Car: 1982 Recaro T/A
Engine: LU5 CFI 305 V8
Transmission: TH-200C
Axle/Gears: 3.23 F-body Fanatic: Yes
My 2.8V6FI was intermittently bucking like crazy, really shaking things up in the transmission and rear end there for a while
It turned out to be code 34 & 45. 45 points to the O2 sensor, which was fine. 34 is the MAF. www.thirdgenresource.com (Charlotte, NC) gave me one off an 85 camaro for $35 and my car's been fine ever since. They even installed it for free. Awesome people and really courteous. If you're in the area check 'em out.
1982 Recaro Trans Am LU5/WS6/Y84, lowest mileage '82 T/A yet! - http://indiemonkey.com/82recaro
1985 basic Firebird, LB8/F41/GU6/DE1, '82 T/A wheels, CB, 128k - Get JPG picture here
[This message has been edited by kizz (edited June 01, 2001).]
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
