HELP ME I'M MELTING
Old Jun 14, 2001 | 07:34 PM
SMB420's Avatar
HELP ME I'M MELTING
I HAVE AN 89 CAMARO WITH A V-6 FUEL INJECTED ENGINE. I KEEP BURNING CAPS AND ROTORS EVERY TWO WEEKS. CHANGED THE COIL, CONTROL MODULE, SPARK PLUGS, AND WIRES, AND CHECKED GROUNDS. I STILL CAN NOT FIND OUT WHY THEY KEEP MELTING. IT HAS 200,000 MILES AND RUNS GREAT OTHERWISE. ANY INSIGHT???? THANK YOU
Old Jun 14, 2001 | 09:48 PM
Camaro_hunter_d's Avatar
hmm...well I suppose you don't know if its outside heat or internal. You might want to drill a small 1/16 or smaller into your next cap. This will let some flow from the cap and get rid of some of the ionizaion that happens inside the cap. Other than that I have no clue what could be causing it...
Old Jun 15, 2001 | 10:18 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Is the plastic itself melting, or are the terminals getting eaten away?
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Jun 16, 2001 | 03:45 AM
SMB420's Avatar
Will that hurt the integrity of the cap? where should i drill the hole? thank you i will try this.
<font face="Verdana, Arial" size="2">Originally posted by Camaro_hunter_d:
hmm...well I suppose you don't know if its outside heat or internal. You might want to drill a small 1/16 or smaller into your next cap. This will let some flow from the cap and get rid of some of the ionizaion that happens inside the cap. Other than that I have no clue what could be causing it...</font>
Old Jun 16, 2001 | 09:25 AM
Well if the back of the cap should be fine...and no it will not hurt the integrity of the cap. there should be one in the cap already but it may be too small... just do not drill the hole directly below a contact point.
8889gtaformula
Exterior Parts Wanted
Nov 5, 2015 04:17 AM
wstephan96
Sep 25, 2015 04:28 PM
corey8084
Sep 17, 2015 02:56 PM
89GTA5spd
May 21, 2001 05:55 PM
Artic White Z
Apr 13, 2001 07:09 PM
