Did i find the rattle????
Old Jun 19, 2001 | 03:50 AM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
Ok remeber how i kept hearing a rattleing sound form my drivers side of the engine under acceleration oly when i grar well erler today i went to get somethign from under the passger seat and i her arattle coming from my CAT could that be the sound ie been hearing??? i think it is but the part i dont get is why would i hear it on the drivers side wouldnt i hear it at the passangerside? any ideas im gonana check my cat after i get my car DETAILED tommorw oh ya So fresh and so clean hehe..
Old Jun 19, 2001 | 07:26 AM
El Guapo's Avatar
The reason you would hear it on the driver's side is because thats usually where you sit, right? Sound travels.
Ex, when my transmission mount went out, it took me a while to figure it out, why? because depending on where you stood or sat, it sounded like it came from a different part of the car.
If you can hear the car rattle when you getting something out of the pass seat, then it probably has something to do with it. May just need a rubber grommet or somethng.
Clayton
Old Jun 20, 2001 | 01:24 AM
Camaro_hunter_d's Avatar
heat shield. tack weld.
Kills to date a 3.1 firebird 2 stop lights in a row.
95 Grand Am
Serveral Honda's
a friends 91 Rustang LX(I know its a 4 but he keeps trin')
Planned mods:
Soon coming 3 inch exhaust, 1.6 rockers, High flow 'Verter, and Ignition system. Along with a complete turbo 4.3 swap planned later this year(hoping to get into the 10's..)
Current mods:
Set of Iroc sway bars front and rear..amazing differance, Air box bottom completely removed allowing my K&N to act like an open element filter.
Lower profile tires, 195/55/15 front 205/55/15 rear handles better.
And a 160 deg thermo for a V8(and yes it works just fine)
Sterio Sony CD head unit and 9 band EQ, Boston acutics 4x6 dash, Alpine 3 way 6x9 sail, California sounds active crossover, Kroiiler 600 watt amp powering the 'pines and Bostons, 600 watt Jensen powering 2 Rockord Fosgate RFZ1812 subs. And all this cost less then $575...
GouldyGTR
Sep 7, 2015 09:05 PM
90formulaVortec
Exterior Parts Wanted
Sep 7, 2015 07:17 PM
Ian Irvine
Sep 4, 2015 08:08 AM
