V6 help needed... start up sputtering and interstate shut off...
Old Jun 30, 2011 | 05:32 PM
89Camaro88's Avatar
Car: 1989 Camaro RS
Engine: 2.8l V6
Transmission: Auto 4
Today I was driving on the interstate when my car just decided to shut off it does have a new fuel filter and was running great before today. It would start but would immediately sputter unless you held the gas half throttle then it would run but when you let off of the throttle it would immediately start sputtering again. So I just had it towed to my house. What would cause this?
It has been shifting late at around 4500 rpms and has slow acceleration issues...
Old Jun 30, 2011 | 07:53 PM
Project 3.4 Camaro's Avatar
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
Re: V6 help needed... start up sputtering and interstate shut off...
Probably dead full pump, but a vacuum leak could also cause such a problem.
Old Jun 30, 2011 | 10:40 PM
89Camaro88's Avatar
Car: 1989 Camaro RS
Engine: 2.8l V6
Fuel pump is fine it is putting out 38 at the fuel rail... but I know that I have vacuum leaks off of my EGR valve and somewhere else on the smog system... I know there are more but I have to find them... The timing is off just a little but hopefully that will be fixed by tomorrow afternoon... Any more suggestions
Old Jul 2, 2011 | 11:11 PM
89Camaro88's Avatar
Car: 1989 Camaro RS
Engine: 2.8l V6
Well it turns out it was the coolant temperature sensor because the thermostat is bad and not allowing the coolant to circulate correctly.
So thursday, it is getting new plugs, wires, thermostat, coolant temperature sensor, exhaust manifold gaskets, and vacuum lines, and tires...
Orr89RocZ
Apr 25, 2016 08:28 AM
Andrew6.688
Dec 13, 2015 10:59 AM
Camarothatcould
Aug 20, 2015 08:49 AM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
Fronzizzle
Aug 9, 2015 01:15 PM
