gear ratio
gear ratio
what is our stock gear ratio....and where can you look to perhaps see if you rear end ratio is not stock.
1990 Firebird 3.1
- Auto Trans, TA Body Kit
- Home Made C.A.I.
- ASP Underdrive Pulleys
- MSD 8.5mm Superconducter Wires (custom-cut)
- MSD GM Blaster Coil
- AC Delco Cap & Rotor
- Bosh Platinum +4 plugs
- Mobil 1 Synthetic Fluids
- 2.5" Hooker Aero-Chamber Cat-back
- 2.5" Hooker Elite Stainless Extension Tips
- GTS Blackouts (stickers removed)
- TB Bypass
KILLS = Dodge Daytona (stick), 2000 Toyota 4 Runner 4WD,
1997ish Ford Explorer, "older" Jeep Cherokee (don't ask why they are all SUVs...who the hell knows?)
LOSSES = 300zx (had him half way through 2nd, he was manual)
"The racing dice added 5hp...I SWEAR!"
1990 Firebird 3.1
- Home Made C.A.I.
- TB Bypass
Not stock, look at the back gear cover. You may notice some goo oozing out from cover from a rebuild.
Stock may be a 3:23.
My 1985 is a stock 3:42, non-posi, DRAT!
Love the gears, hate the peg leg burnouts
Chat Soon,
KED85
Karl
1985 Firebird 2.8 to 3.4 swap project for Smog Happy LA, CA
Chat Soon,
KED85
Karl
Car: 1986 Firebird
Engine: 2.8 V6
It's messy, but you can pull off the rear cover & count the teeth of the ring gear & pinion gear, then divide 'em. Might be a good idea anyway, your rear fluid's probably never been changed.
If you luck out, there's a 3-digit code stamped on the FRONT of the passenger side axle tube. The Haynes manual lists some of the codes in it; that code will tell you the rear gear, and if you have a posi or not. The code #'s hard to see, you'll need a wire brush & wet rag to pick up on it.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Hotrodboba400
Dec 10, 2019 07:07 PM
dbrochard
Sep 19, 2015 08:13 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
