Grant GT Wheels
Old Jul 1, 2001 | 02:26 PM
fiream's Avatar
Car: 1983 Pontiac Firebird
Engine: 400HP 350
Grant GT Wheels
I was in the parts store the other day and i saw a Grant wheel #773 on sale and i thought my that will look good on my firebird. So i picked-up the wheel and the grips felt pretty good, but i don't i know it might make the car look good but will the feel of the handling of the car be different since the Grant wheel is 13" Dia. and my stock 83 wheel is 14" Dia. What do you guys think, or do any of you have one already??
Chevy 2.8L, k&n filter lid, Headers Soon!!!
Old Jul 1, 2001 | 04:54 PM
CaliCamaroRS's Avatar
Engine: LH0 3.1L
I have a Grant wheel and i love it. I'm not sure what size it is but it's smaller than stock but not too small. It's the perfect size for whipping the steering wheel around.
-Dan
-1990 3.1L RS
-Mods? no
-Slow? yes
Old Jul 1, 2001 | 04:57 PM
fiream's Avatar
Engine: 400HP 350
It's probably a 13" was it easy to install?
Old Jul 1, 2001 | 05:04 PM
Engine: LH0 3.1L
Sorry, i bought my car with it already on. It seems like something that should be easy but i don't think it is. Try asking in General Tech cause i'm positive somebody has installed one there.
Old Jul 1, 2001 | 05:12 PM
Engine: LH0 3.1L
Or i guess you could ask in Body/Interior too.....
Old Jul 1, 2001 | 05:51 PM
CC_HotRod's Avatar
Car: 1984 Camaro
Engine: V6
Transmission: 700 R4
Whenever I got mine I also purchased the installation kit. As long as your car doesn't have an air bag it is just a matter of using a steering wheel puller a pair of pliers to remove the clip and a ratchet & scoket to remove the nut.
Dale Earnhardt was a scholar of the race track that drove with the spirit of a warrior.
My Camaro: http://home.earthlink.net/~singleton052095
Old Jul 1, 2001 | 05:55 PM
Engine: LH0 3.1L
Yeah, if it's pre 1990 it shouldn't be too hard. Mine had an airbag and i assume that removing it would throw a code or something....then you'd have to fix that.
Old Jul 1, 2001 | 06:07 PM
fiream's Avatar
Engine: 400HP 350
That sound easy enough. I got an 1983 firebird. But will it afect steering at all?
Old Jul 1, 2001 | 10:52 PM
85f-bird's Avatar
Car: 85' Firebird (Project), 92' RS
Engine: 2.8L, LS1
Transmission: 700R4, 4L60E
Axle/Gears: 3.42 Open , 10 Bolt (ukn)
hey,
my cars been rained in a couple of times now, and the leather wrapped steering wheel is falling apart. and of course GM doesn't have anymore in stock, so i was thinking of a grant, because most of the boneyard ones will be worse than mine. But my question i will my firebird horn button work in the grant wheel? cause i like the screaming chicken in the middle.
Old Jul 1, 2001 | 11:05 PM
fiream's Avatar
Engine: 400HP 350
you know what that's what i've been trying to find out myself. Grant make a Pontiac Emblem for the wheels, but not a bird. What year is your car? I have an 83 and the center bird on my car is alomst like a sticker or something i think i can remove it but then again i haven't taken the wheel apart yet. They do make a black horn button so you can put a decal or stick of what ever you want on the center.
Old Jul 2, 2001 | 06:20 AM
Brian K's Avatar
I have a GT Grant Wheel and it has been great.. Looks cool and was easy to install...
Old Jul 2, 2001 | 01:46 PM
elevario's Avatar
Car: 1992 RS
Engine: 3.1L V6
So if I have the steering wheel with the airbag I can't change to a grant wheel real easily? And you can use your horn?
V6 Bone Stock
Old Jul 2, 2001 | 03:59 PM
fiream's Avatar
Engine: 400HP 350
The only problem with installing a grant wheel in place of a wheel with an airbag is you will have no airbag. but you can get away with it if you don't want an airbag. also the computer will throw a code, but you can get around that by pulling the fuse that controls the airbag.
Old Jul 2, 2001 | 04:05 PM
Camaro_hunter_d's Avatar
OK well I got a grant about 2 months ago, and I love it. I had an airbag, removed the bag after taking many, many precautions so it not go off. It's not hard with the airbag either, just remove the fuse, the battery cable, the yellow wire at the base of the steering column and the column switch behind the wheel(a black disk type thing) You just have to deal with the red light being on all the time.
The diameter is 13 inches so the steering response is a little faster too...
Old Jul 2, 2001 | 07:35 PM
Ovrclck350's Avatar
Also remember if you change to a non-airbag wheel in an airbag equipped car to keep the original wheel. It's illegal to sell an originally airbag-equipped car without an airbag.
Old Jul 2, 2001 | 10:59 PM
85f-bird's Avatar
Engine: 2.8L, LS1
my 1985 wheel doesn't have a sticker on it, the horn button is rubber, and the bird is embosd into it. IT looks really nice, and i'd like to keep the bird.so i'll keep searching bone yards.
Old Jul 3, 2001 | 08:55 AM
KED85's Avatar
A smaller diameter wheel will make your car feel like it has a quicker steering response.
The idea works rather well.
Think of a race car, ever see a "stock size wheel"?
Only NASCAR has the "stock" size wheel. They have to slow down steering response for going 200MPH.
I put one of those wheel on my S-10 Blazer.
Blazers have slower steering than the F-3 (it is a truck, after all). That change made a world of difference.
I am going to be getting a Grant Wheel for my Wife's 1968 Camaro, the Classic Wood style one.
I have to change her turn signal switch, off comes the wheel!
BE REAL CAREFUL REMOVING A STEERING WHEEL, FIRST TIME!
You can break your nose, real easy!
The 1985 one on my Firebird is exactly like described, "Leather" (is it really leather?), with embossed rubber horn button of the famous screaming chicken. Mine, for a CA car is in exceptional shape.
No, that screaming chicken horn button will not work with the Grant set up.
Chat Soon,
KED85
Karl
1985 Firebird 2.8 to 3.4 swap project for Smog Happy LA, CA
Old Jul 3, 2001 | 09:18 AM
fiream's Avatar
Engine: 400HP 350
do you mean break my nose? Do you mean when i try to pull the wheel off? I thought you were supose to use a wheel puller?
Old Jul 6, 2001 | 01:11 AM
88-RSport's Avatar
I got a classic 10 inch wheel for my car, and I can tell the difference in handling. Turn the wheel once for a u-turn. Just gotta fix my damn horn now.
88 RS----
K&N filters.
ram air setup.
speed limiter bypass.
flow master exhaust.
advanced timing.
Quick pick up top end...
Kills:
Freeway----
99 Rustang (5 speed v6. )(No contest)
98 Eclipse Rs(never had a chance)
92 Integra(what the hell was he thinking)
99 Civic rice wagon
87 B2000 (He started it)
Street---
84 Hundai(Don't ask)
98 VW Beetle
89 Sentra
Old Jul 6, 2001 | 01:42 AM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
I want a 6 inch chain wheel lil like the mexicans have like they had in cheech n chung up in smoke lol i think thad look funny lol.
Old Jul 6, 2001 | 11:15 AM
fiream's Avatar
Engine: 400HP 350
The chain wheel can be found in Jegs high preformance mail order,
Parts number: 470-740
Price: $62.99
Hope this helps,
Rob
http://www.geocities.com/fiream/RobsCarArtPa.html?994187591828
Old Jul 6, 2001 | 12:11 PM
<font face="Verdana, Arial" size="2">Originally posted by fiream:
</font>
He means blowing the bag... You will end up in the back seat in a VERY painful way!...Not speakng from experiance.
Old Jul 6, 2001 | 01:53 PM
fiream's Avatar
Engine: 400HP 350
Okay, I get it now. Is there any place that sells a horn button that will fit the Grant Wheels that has the Firebird symbol on it?
Old Jul 6, 2001 | 08:26 PM
CC_HotRod's Avatar
Car: 1984 Camaro
Engine: V6
http://www.grantproducts.com/idea.html
This is Grants Web Site they have a Pontiac emblem but no Firebird. Maybe send them an e-mail requesting one..who knows, if they get enough requests they may start making it.
[This message has been edited by CC_HotRod (edited July 06, 2001).]
Old Jul 6, 2001 | 11:50 PM
fiream's Avatar
Engine: 400HP 350
Would a custom graphics shop be able to make a vinal decal that small to fit on grant's plain black horn button?
Rob
Old Jul 7, 2001 | 11:23 AM
CC_HotRod's Avatar
Car: 1984 Camaro
Engine: V6
Maybe you could try taking a plain horn button to a Trophy shop or any other place that does engraving and have it engraved onto the button.
My local trophy shop has the equipment to download images from the net and engrave them to the item.
Old Jul 20, 2001 | 12:54 PM
fiream's Avatar
Engine: 400HP 350
I got a question. I was installed my wheel yesterday it seems now that the car is really out of alinement, is that because i went from a 14.5 inch wheel to a 3 inch wheel. I know I installed the wheel right, I followed the directions to the Tee. The whell only when on one way, maybe the is way out of line and I didn't notice it until i got the new wheel.
Old Jul 20, 2001 | 03:29 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
CC_Hotrod, that's a btchin' idea! That's one of the things that kept me from getting a wheel- losing the Firebird horn button.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Jul 20, 2001 | 08:11 PM
KED85's Avatar
Reason why I said you can break your nose.
You are dead in front of the steering wheel as you are cranking it off the column.
All the sudden it pops at you.
And your nose is right there.
I'll give ya a guys email address at Grant to make your request.
I'm getting a wheel from him for my Wife's 1968 Camaro.
This guy Robert will be HAPPY TO ASSIT YA IN YOUR CHOICES AND QUESTIONS.
Let me ask him & I'll send him this thread, too.
Be patient.
This evening, I sent him this thread.
I told him about everyone here and let's see if Grant Products can give us an answer.
We'll have to wait until Monday or Tuesday (when he gets this at work!).
Maybe we CAN get that special emblem!
Chat Soon,
KED85
Karl
[This message has been edited by KED85 (edited July 20, 2001).]
Old Jul 20, 2001 | 08:18 PM
HIX5000's Avatar
I sell atleast one Grant wheel a week. Every costomer that comes back in says they love the wheel.
Old Jul 20, 2001 | 10:18 PM
fiream's Avatar
Engine: 400HP 350
I never though it was that easy to install the wheel, it only took me an hour and a half.
Old Jul 20, 2001 | 11:09 PM
CC_HotRod's Avatar
Car: 1984 Camaro
Engine: V6
<font face="Verdana, Arial" size="2">Originally posted by TomP:
</font>
Thanks Tom....once in awhile I get a flash of intelligence...
obeymybird
Exterior Parts for Sale
Nov 3, 2015 08:10 AM
drptop70ss
Oct 4, 2015 09:44 PM
Saxondale
Sep 15, 2015 06:42 PM
punkmaster98
Sep 8, 2015 09:45 PM
turbobuick88
Wheels and Tires
Sep 8, 2015 08:27 PM
