cat to intermediate pipe flange bolts?
Old Jul 9, 2011 | 07:01 PM
notsonic's Avatar
So I'm doing exhaust work and cut the old stuff off. I go to bolt up the new cat and intermediate pipe and realize i had cut the old bolts, and there were no new bolts.
Anyone know the size of these bolts? I suppose its not all that important though.
It's an 85 2.8l.
Also, another question. I've found listed on lots of parts catalogs a set of bolts and springs for somewhere on the exhaust. Where would these go? The manifolds I've got have studs (which of course broke.)
Like these here: http://www.rockauto.com/catalog/moreinfo.php?pk=123486
Old Jul 9, 2011 | 07:46 PM
oldschool's Avatar
Car: 1985 Pontiac Firebird
Engine: 2.8 LB8 HO
Transmission: 700R4 with OD
Axle/Gears: 10 bolt 7.625 open-factory 3.42
Re: cat to intermediate pipe flange bolts?
The bolts that connect the intermediate pipe flange to the cat on the 85-89 2.8 V6 are listed as Hex M10x1.5x50. Should be able to find them in any parts store. The bolts and springs listed on Rockauto's site are for connecting a new cross over pipe to the manifold.
Old Jul 9, 2011 | 07:55 PM
notsonic's Avatar
thanks for the info.
should i use the bolts/springs or studs?
Old Jul 9, 2011 | 07:59 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Just get a pair of bolts with locking washers that fit and get it done. The bolts with springs are meant for the manifold flanges and DO NOT fit (tried them) on our manifold flanges.
Old Jul 9, 2011 | 08:01 PM
notsonic's Avatar
ok cool. yeah i have the new studs for the manifolds already, bolts would be way easier to work with but if they don't fit no need. wonder why they're listed.
Old Jul 9, 2011 | 08:03 PM
Engine: 2.7L V6
Axle/Gears: 4.41
The manifolds can use bolts, but not the ones with the springs, since they have a step on them at the end of the threads that catches on the flange before they even reach the manifold hole.
I don't know why they list the bolts with the springs, but I do know they fit on the FWD engines...
Old Jul 10, 2011 | 09:15 AM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
i just went and got bolts at my local hardware store, cost like $15 somethin and i used the old springs aswell.
LT1Formula
20
Nov 14, 2015 12:02 AM
FreeSpirit
Aug 29, 2015 05:47 PM
Chiknhawk
Aug 23, 2015 05:54 PM
Out-Cast
Aug 22, 2015 07:49 PM
Amillionoh7
Aug 7, 2015 01:24 PM
