Stall Converter
Old Jul 26, 2001 | 04:44 PM
Purple Monkey's Avatar
Car: 1990 Eagle Talon TSi AWD
Engine: 4G63T
Transmission: 5 speed
Stall Converter
ok, I have an 89 firebird with the 2.8 and it is way too slow! or at least it was before the tranny went out, so I'm rebuilding it and putting a shift kit in it. I also wanted to put a higher stall converter in it while I was at it. Any reccomendations?
THe only performance parts are accel cap rotor coil and wirs and bosch +4 plugs, and it's got dynomax exhaust. Any other suggestions would be great too thanks...
Old Jul 26, 2001 | 04:52 PM
V6camaroman's Avatar
get a b&m holeshot 2400 stall converter. in summit for $334.95
Old Jul 26, 2001 | 05:04 PM
ideas for you engine. port,polish,rebuild heads,new guides. Double roller timing chain.
3 deg valve angle job. push rod & rockerarm kit. port & polish intake manifold. edelbrock performer plus camshaft kit #3790.
flow tech performance headers. bore engine .030 over. complete rebuild kit. new distributor. hop up ignition. weiand water pump. high performance oil pump. If i find any more ideas i will write to you!
Old Jul 26, 2001 | 05:54 PM
Engine: 4G63T
I was thinking something a little more mild, it's just my economy car I have a camaro to go fast, I'm just tired of flooring it all the time just to get it to move...
Old Jul 26, 2001 | 05:58 PM
Graeme'sFirebird's Avatar
From: First one out of liberty city, burn it to the ground
flooring it to get it to move? Im assuming ur exaturating...?
1989 Firebird
2.8 v6, t5 swapped in
Ram Hi-po clutch, Cold Air, 1.6 rockers,Lakewood LCA's, Lakewood Lift bars, Wonder Bar, 3" y-pipe, Random Tech Cat, 3" I-pipe, Flowmasters, MSd 6a, MSD Coil, Accel 8.8 wires, Auto Meter Gauges (Water, Clock, Fuel Pressure, and 5" Sport Comp Tach)TB Bypass, 4th Gen Seats
Coming for my v6:
Panhard Bar, 4thgen front seats, Nitrous, Line Lock, Posi, Spohn Torque Arm & Subframe connnectors
"I'd rather run last in a full out race, than to NOT have run at all"
#3 Forever
Old Jul 27, 2001 | 03:10 AM
Engine: 4G63T
I wish I was, I've never driven any other v6 f-bodies, but I don't think this thing should be this slow.
Hotrodboba400
Dec 10, 2019 07:07 PM
customblackbird
Oct 1, 2015 04:30 PM
amcnellis
Sep 16, 2015 04:16 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
