Clutch not clutching
Old Aug 6, 2001 | 07:26 PM
Little E's Avatar
I just completed the tranny swap and finally got the thing started. I went to put it into gear and it didn't want to go. I haven't bleed the slave cylinder yet because my friend never opened the system when he took it off. I checked under nieth and have about 3/4 -1 of travel. Did i put the throw out bearing in wrong or do i need to bleed the system or am i on the wrong track
Thanks for the help!
Old Aug 6, 2001 | 10:59 PM
86Chicken's Avatar
The spec is that the slave piston should extend .57", if it is more then that is OK.
Can you run thru the gears while the engine is not running?
Dale
1986 FireBird
2.8L MPFI
Gutted Cat, No muffler (Sweet Sound)
Was 700-R4 --> Now T5
Old Aug 7, 2001 | 12:06 AM
Little E's Avatar
Ya, i can shift through all gears while no running. Once it starts, i can't shift the gears, it'll just grind, like there is no clutch.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
meeklay812
Oct 1, 2015 03:46 PM
mfp189
Sep 27, 2015 09:25 AM
jtwoods4
Sep 3, 2015 05:39 PM
