How often should I clean my K&N's???
Old Aug 5, 2001 | 08:41 PM
Jason E's Avatar
2011 Norwood Gathering
ThirdGen Firebird Rep
Car: 99 WS6 / 00 SS / 11 CTS-V / 13 300
Engine: LS1 / LS1 / LSA / 5.7 Hemi
Transmission: 4L60E / T-56 / 6L80E / W5A80
Axle/Gears: 3.23 / 3.42 Auburn / 3.23 / 2.62
I put them in at 77,300 and now have 92,800...is it time? I took the baffles out of the airbox, so there is certainly a slight glaze of dirt over much of the filter surface, but I read somewhere that a slight amount of dirt actually helps filtration and flow...is this true?
Jason E
'89 Camaro RS
-Medium Grey Metallic
-2.8, A4, T-tops, 92k miles
-Hypertech chip, Accel wires/coil/K&Ns
-Alpine 60x4 and Bostons
'97 Z28
-30th Anniversary package (white with orange stripes)
-LT1, M6, t-tops, 44k miles
-Eclipse CD and 10" Aluminum sub in JL Audio Stealth box, Boston RM speakers, Xtant 403a amp
Speed Kills...Wanna live forever? Drive a Ford.
Long Live #3...
Old Aug 6, 2001 | 03:03 PM
AntiVTEC's Avatar
you should clean them pretty often, especially if you got gutted air boxes. Dirt leads straight to the filters rather than being clogged up by the baffles. Whenever I clean my filters, the intake regains is swhooshing noise, and thats only after about 4k miles. Also depends what conditions you drive in.
85 2.8L Sport Coupe 5-speed.
Mods: Hpertech chip and powerstat, MSD 6A-L, Crane fireball coil, Accel Cap and Rotor, Dynomax hi-flow cat and catback system with a dynomax magnum race bullet muffler on the i-pipe, K&N filterchargers, Gutted Air Boxes, 8mm Wires, Eibach Sportlines and Tokiko springs/shocks setup, Global west sub frames, Suspension techniqs front and rear sway bars, and good ole 88 IROC wheels with Kumo Ecstas on em!
"It's not the ricers, it's those damn V8's!"
Wins: 2000 V6 Accord, 69 302 Mustang, 2000 Auto VR6 Jetta, 89 Toyota MR2, 90 Civic Si, 76 350 Camaro.
Old Aug 7, 2001 | 10:38 AM
KED85's Avatar
On my cars with cold air induction (like my Wife's 1968 Camaro with straight six) I have to clean it real often.
Dirt impedes air flow.
Use Simple Green to soak clean, rinse with cold water, shake to get rid of water, let dry in sun, spray with K & N oil stuff for usage.
I have stopped using the K & N for CLEANING the filters. Simple green works very well and it way more useful for other things, too. So, to me, it's more value cost.
Chat Soon,
KED85
Karl
1985 Firebird 2.8 to 3.4 swap project for Smog Happy LA, CA
Old Aug 7, 2001 | 08:34 PM
Jason E's Avatar
Simple Green, eh?? I didn't know this was safe...I have a ton of it!! You've used this stuff for awhile with good results??
As for gutting the airboxes, I haven't yet, but I do want to! I have removed the baffles however, and did notice a sharp increase in the amount of dirt on the filters...
Old Aug 7, 2001 | 10:11 PM
KED85's Avatar
yea, been using it that way for years now
a friend turned me onto that tip.
put in spray bottle,use it that way, full strength.
yea it works real well
Chat Soon,
KED85
Karl
Old Aug 8, 2001 | 07:20 AM
Brian K's Avatar
I do every oil change.. Usually it just needs oil, but I try to do it no less than 3-4 times a year...
Hotrodboba400
Dec 10, 2019 07:07 PM
codeysabatini
Nov 10, 2015 04:07 PM
1990FirebirdGTA
Sep 22, 2015 07:26 PM
edoff13
Sep 11, 2015 03:55 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
